Best Way to Cool the Engine?
Old Apr 25, 2002 | 04:04 PM
Flux's Avatar
Default Best Way to Cool the Engine?
Not much traffic over in Competition right now, so I'll post here as well...
As the temps start rising (it will be near 90 here this weekend) I'm starting to wonder what is the best way to cool an engine between autox runs?
Should I shut off the engine and pop the hood? Keep the motor running and turn on the heater?
thanks
Old Apr 25, 2002 | 04:06 PM
Big Phat R's Avatar
Default Re: Best Way to Cool the Engine? (Flux)
Keep the heater on full blast before,during and after your run.
Go for an extended cruise after you run (if possible) to cool the brakes.
Other than that, park in a shaded area (again if possible) and pop the hood.
Old Apr 25, 2002 | 05:09 PM
Razor's Avatar
Default Re: Best Way to Cool the Engine? (Phat Bastard)
damn isn't that a little too much(during the run)?
Old Apr 25, 2002 | 05:13 PM
hybrider's Avatar
Default Re: Best Way to Cool the Engine? (Razor)
i wouldnt put it on during the actual run, but otherwise a good idea
Old Apr 25, 2002 | 05:52 PM
t's Avatar
t
ice
Old Apr 25, 2002 | 05:58 PM
DC2ITR's Avatar
the heater on?
how dose that cool the engine? but i'll be crazy hot for the driver?
Old Apr 25, 2002 | 06:07 PM
B2FiNiTY's Avatar
This thread should answer all your questions:
https://honda-tech.com/zerothread?id=132235
Old Apr 25, 2002 | 08:24 PM
Big Phat R's Avatar
Default Re: Best Way to Cool the Engine? (DC2ITR)
the heater on?
It works great. Keep the windows open and adjust the vents so they don't blow in your face. If it is too hot then you are a *****, plain and simple
Old Apr 25, 2002 | 08:32 PM
disordeR's Avatar
the heater on?
heater takes heat away from the engine. also good to know if you ever overheat, pull over and turn on your heater.
Old Apr 25, 2002 | 08:33 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Best Way to Cool the Engine? (disordeR)
Get the Spoon thermostat, radiator cap, and when your not running keep the hood open.
Old Apr 25, 2002 | 08:44 PM
csufweed's Avatar
Default Re: Best Way to Cool the Engine? (comptechgsr2000)
run some redline water wetter in your coolant as well and if you want, get a B&M oil cooler.
Old Apr 25, 2002 | 08:45 PM
Type Goch's Avatar
New User
maybe a turbo timer?
Old Apr 25, 2002 | 09:07 PM
SpeedPak's Avatar
Default Re: Best Way to Cool the Engine? (csufweed)
yea no need during the run...but always always let the car run for some time at idle before you shut her down....and while you're doing that run the heater...also pop the hood but i usually dont pop it all the way up, i use a bar or something to raise the hood but still shade the engine....
for autox its less of a big deal. For a national, div or Prosolo event yea I'd do it. for a local its not too big a deal..but always do so after lapping on track.
fais
Old Apr 25, 2002 | 09:43 PM
JeffNA's Avatar
Spoon Radiator Caps $35 shipped.
Old Apr 25, 2002 | 10:21 PM
Kengs's Avatar
Default Re: Best Way to Cool the Engine? (JeffNA)
Test with J's racing carbon hood - 13 C degree difference from the stock hood:
The temperature of engine room was 78.1 C (172.6 F) and the water temperature was 101.8 C (215.2 F) after the 5 laps. The differences from the stock hood are 6 C degree for the water temperature and an impressive 13 C degree for the engine room temperature.
Taken from Racing Craft's website - product in question is the Crux C/F hood for EK9 Civic (vented). Maybe use a vented hood in conjunction with a higher performance radiator like RG?
[Modified by kengs, 2:22 AM 4/26/2002]
blah13
Apr 16, 2003 09:45 AM
echo999
Sep 5, 2002 10:36 AM
Flux
17
Apr 28, 2002 12:53 AM
