A/C in a B16a?
Old Apr 25, 2002 | 03:59 PM
OldSchoolCrxSiR's Avatar
Default A/C in a B16a?
how hard is it to put a/c in a b16a in a 89 hatch!
what parts are needed!
thanks!
Old Apr 25, 2002 | 04:26 PM
mafioso102's Avatar
New User
Default Re: A/C in a B16a? (HondaHb916)
hasport sells an ac bracket for $200
Old Apr 25, 2002 | 07:25 PM
B16ED4G's Avatar
assuming that your car had operational A/C before you did the swap, you have a few options. Some of the makers of the mount kits also make A/C brackets to adapt your stock A/C compressor to the B16 Engine. Such as Hasport, Place Racing etc. I would reccomend buying the bracket from the Co. that made your mounts, because they make the braket work with their mount kit. Others may work fine, I don't know. Or you can do like I did. If your B16 was from an integra XSi and came with the XSi A/C bracket, AND your A/C compressor is the SANDEN. two of the bolt holes will line up with that bracket, I made another bracket to support the rear of the compressor, its not hard, just use a little inginuity. Beats forking out $200 just for a bracket, especially in my case where I had to buy a new compressor as well. The SIR bracket is slightly different and only one of the bolt holes line up. I would not reccomend using this bracket because of poor crank pulley/A/C compressor alignment. It would probably squeal, and chew up the belt being misaligned
Chris
Old Apr 25, 2002 | 10:27 PM
wickedxboi's Avatar
Default Re: A/C in a B16a? (B16ED4G)
i just had the guy at the shop modify a gsr a/c bracket and it fits just fine.
Zaakro
Nov 12, 2005 04:34 PM
Jesterian
14
Sep 25, 2005 06:03 PM
StorminMatt
Aug 20, 2005 07:05 AM
91hatch_on17's
Mar 25, 2004 06:01 PM
red civic standard
Apr 29, 2002 08:00 PM
