Mid-Atlantic (Sales) VA, DC, and MD
FS: 11/12 Second 1995 Jetta VR6 Trubo (400whp)
Old Aug 17, 2006 | 11:01 AM
vr6mole's Avatar
Default FS: 11/12 Second 1995 Jetta VR6 Trubo (400whp)
Ive had fun. Time to move on. Car has undergone MANY changes since last year. All for the better. Drivetrain is 100% bulletproof (see 6 speed and stage 3 axles).
Engine temps are MUCH cooler due to all the heat material.
Anyone with any questions can reach me at 610-757-4649.
Lowered price. 11.5k bring on the offers!
Eurotuner January 06 Feature Car!
Movie of the 12.60 run, http://www.personal.psu.edu/us...0.wmv
1995 Jetta VR6
408whp/424wtq on 22psi
12.13@118
daily driveable
Engine
Completely rebuilt long block
ARP main, head, and rod bolts
Turbonetics 60-1 TO4 turbo w/ .58 ar, ceramic ball bearing
C2 Motorsports 9.0:1 headspacer
42# 440cc green top injectors
C2 Motorsports 95mm custom polished MAF housing
Tial 38mm external wastegate (vented to atmosphere)
3 inch turbo back
3 inch borla XR-1 Race muffler
Spec Stage 3 Clutch
Eurospec flywheel
painted/polished engine parts
33x11x3 Intercooler
Black IC piping
ATP manifold w/ relocated WG flange
Trac Racing Stage 3 head
Schrick valve springs and retainers
C2 Motorsports 42# chip (custom tuned)
Stage 4 turn 2 motor mounts
HD tranny mount
C2 Motorsports Short Runner
Ceramic Turbo Blanket,
Wrapped Downpipe
ATP Heatshield
DSS Stage 3 Axles
Quaife 6 speed synchromesh gear set
Quaife LSD
Mocal 19 row oil cooler
Shaved Engine Bay Details
Opitma redtop battery relocated to trunk
all battery related wiring upgraded to 2 gauge cable
ECU relocated to cabin
main engine harness hidden
low profile rad fans
all coolant system related wiring deleted
Expansion bottle removed
CSR inline filler
CSR billet cap
Flipped starter
removed ABS wiring
removed cruise control
removed EGR
removed secondary air injection
A/C removed
corrado thermostat housing cover
Exterior
Tornado Red w/ red pearl
Fiber images Carbon Fiber Hood w/ red weave
FK 3 bar grille
Smoked GTI ecodes
Votex Smoked long fogs
Smoked turn signals
corrado wing
pulled rear arches
shaved weld lines
shaved vw emblem
sparco gas cap
mercedes sprinter vent
euro plate tub
texture top bumpers
euro vr6 lip
Euro rad support
Suspension/Brakes
H&R coil overs
Non-ABS master cylinder
Shine racing rear sway bar
Wilwood 4 piston Dyna-lite Calipers
Super blue ATE fluid
Wilwood Pads
MMP cross drilled and slotted rotors
Wheels/Tires
Brock B1 Wheels
Toyo T1S Tires
Front
16x7.5 ET 35
195-45-16
15mm spacer = 20 ET final
Rear
16x9 ET 15
215-40-16
Interior
Innovate LM-1 Wideband
Greddy Profec B Spec II Boost Controller
Autometer Boost and A/F gauge
RSD brushed aluminum pedals
Sparco harnesses
Scroth leather harness pads
MOMO jet steering wheel
Euro headlight switch
Panosonic head unit
Arizen Racing Leather Seats (recaro SRD’s)
Comes with a set of DE wheels with drag radials and kumhos as well as a set of 15x8 steelies with brand new 24.5x8x15 MH race master slicks.
Also an extra set of front Toyo T1S 195-45-16 tires brand new.
more pics can be found here
http://forums.vwvortex.com/zerothread?id=2672822
Old Aug 18, 2006 | 10:37 AM
Chronicsinners's Avatar
Default Re: FS: 11/12 Second 1995 Jetta VR6 Trubo (vr6mole)
bump for a local
vr6mole
Sep 14, 2006 06:04 AM
vr6mole
Northern California (Sales)
Aug 21, 2006 05:43 PM
vr6mole
Aug 18, 2006 05:26 AM
vr6mole
Southeast (Sales)
Aug 17, 2006 05:33 PM
vr6mole
Aug 17, 2006 02:39 PM
