Brake Rotors?
Old Aug 17, 2006 | 10:38 AM
Dillon91Teg's Avatar
Default Brake Rotors?
The brake rotors that i have on my car now are cracked and glazed and it makes for a dangerous and uncomfortable stop. i own a 91 integra RS (no abs), and i'm wondering if anybody has made the switch to powerslot rotors. pros/cons? thanks..
Old Aug 17, 2006 | 10:59 AM
Lan's Avatar
Lan
Default Re: Brake Rotors? (Dillon91Teg)
I would stick with OEM. Unless you have brake fade, there is no reason for you to upgrade; well unless you have gobs of power and need to stop because you're driving too fast
Old Aug 17, 2006 | 04:57 PM
PrinceAli132's Avatar
Default Re: Brake Rotors? (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">I would stick with OEM. Unless you have brake fade, there is no reason for you to upgrade; well unless you have gobs of power and need to stop because you're driving too fast </TD></TR></TABLE>
x2
OEM or Autozone rotors
Autozone rotors come with a warranty too, so they are a great deal. Here's a good link that discuss people using Autozone rotors even on the track; https://honda-tech.com/zerothread?id=181691
If you want better stopping power i would consider getting some better pads. But keep in mind that you will make some sacrifices with gettng better pads like more brake dust, might not operate as well when cold, and might squel a little bit more. Also i would recommend getting some better brake fluid like ATE Super Blue.
If it makes any difference i am running autozone rotors, cobalt friction gt sport pads, and ATE super blue fluid.
Ali
Old Aug 17, 2006 | 05:01 PM
Dogginator's Avatar
Daisy... Daisy...
Those slots are great nucleation sites for rust in the wintertime. That cadmiun plating will not last long either. Like mentioned above, stick with blank rotors for the street.
jit01
Aug 29, 2007 12:22 PM
OSIRIuS23
Jan 18, 2006 05:46 PM
Understeer
Dec 11, 2003 05:49 PM
Accorddrver
Jul 24, 2003 05:32 PM
mattmw88
Mar 30, 2002 07:47 PM
