Searched for fitv question and no answer
Old Aug 17, 2006 | 09:51 AM
mikensu's Avatar
Default Searched for fitv question and no answer
My car idles high when the car is cold and after searching I found a lot of people have or had the same problem. Most threads I read said that the fitv could be the problem. But I do not think my 92 civic with a stock d15b engine and tb has a fitv. So what can i adjust and or replace to fix the problem ?? Should I just change the aic valve ?? And if so what controls the idle in my car when it is cold. It idles fine when warmed up. Doesn't the aic control the idle when the car warms up.
Old Aug 17, 2006 | 10:01 AM
instructor74's Avatar
Default Re: Searched for fitv question and no answer (mikensu)
not sure what you are looking for it is normal for the car to idle high until it warms up. it should idle around 1500-2000 rpm when it is cold. after the car is up to normal temp it will idle around 500-600rpm.
Old Aug 17, 2006 | 10:13 AM
mikensu's Avatar
It is abnormally high and it is throwing a error of code 14 which is the aic.
Old Aug 17, 2006 | 10:14 AM
mikensu's Avatar
And the question is does my car have a fitv
Dekorum
Oct 28, 2022 12:59 AM
ChumpChange
Mar 9, 2007 11:58 AM
integra714
May 18, 2005 07:38 AM
rdeezy25
May 17, 2005 01:55 PM
