what rotors do i use for the poormans itr swap?
i've heard different things, i'm getting type r calipers, but I'm not sure what rotors to use......i've heard to use accord wagon, regular accord, prelude and whatever else......so just a quick question i searched.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtak DOHCTA »</TD></TR><TR><TD CLASS="quote">no sorry i forgot to mention i have a 92 integra stock lugs </TD></TR></TABLE>
check on g2ic.com...theres a great thread about the legend/itr brake swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nscirocco »</TD></TR><TR><TD CLASS="quote">92-96 Prelude VTEC rotors, same size as typer with the right hub center
you'll have to re-drill for 4x100
-nigel.</TD></TR></TABLE>
correct
correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtak DOHCTA »</TD></TR><TR><TD CLASS="quote">so i can use stock ls integra rotors... or should i go to bigger rotors to have a up grade?</TD></TR></TABLE>
im pretty sure you need to get larger rotors to go along the larger calipers
Read this thread. It discusses exactly what you need. You will need to machine the caliper brackets as well. My setup is towards the end.
https://honda-tech.com/zerothread?id=734560
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtak DOHCTA »</TD></TR><TR><TD CLASS="quote">what would be easier to go with........? should i just use the prelude rotors and not worry about the center hub......?i dunno which one i wanna go with</TD></TR></TABLE>
The 92-96 Prelude VTEC rotors have the correct center bore for the hub (64 mm). Check out the stock rotor (left) compared to the redrilled Prelude rotor (right) for my car.
I also recall that StopTech is manufacturing a two-piece rotor for the ITR calipers on a non-ITR Integra. I found these after I machined my rotors. The price was about $400 for the pair.
