should i go itb's or turbo??
Old Aug 16, 2006 | 10:21 PM
splickitysplat's Avatar
Default should i go itb's or turbo??
what do you guys reccomend for a 2001 gsr??? my motors fully built for n/a but i was thinking on going turbo and changing some internals to make it turbo capable. and on the other hand, i was thinking to go itb's instead. keep in mind its driven maybe only maybe 2 times a week and always on the weekend to rip **** up.
Old Aug 16, 2006 | 10:29 PM
DPSJosh's Avatar
Default Re: should i go itb's or turbo?? (splickitysplat)
Have you thought about nitrous? I'd go that route.
Otherwise, turbos the way to go man. N/A is awesome but usually expensive and you really cant make much over 240whp N/A without some serious work. Slap on a turbo kit with a decent sized turbo and you'll have atleast 240hp. If you have forged internals then look for around 300hp with a decent tune.
Old Aug 17, 2006 | 05:18 AM
tomlinson619's Avatar
Default Re: should i go itb's or turbo?? (DPSJosh)
pshhhhhhhhhhh>baaaaaaaaaaaaaaaaaa!!!
Old Aug 17, 2006 | 06:06 AM
nathanong87's Avatar
pix of car or ban
Old Aug 17, 2006 | 06:29 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: should i go itb's or turbo?? (nathanong87)
I say get the ITB's and get that bitch tuned.
NA > Turbo
Old Aug 17, 2006 | 11:43 AM
Chris.B.'s Avatar
Default Re: should i go itb's or turbo?? (SlammedDC2)
How much power are you making now?
Old Aug 17, 2006 | 12:13 PM
doood's Avatar
been there done that
Default Re: should i go itb's or turbo?? (Chris.B.)
itb's and turbo
Old Aug 17, 2006 | 12:52 PM
PrinceAli132's Avatar
Default Re: should i go itb's or turbo?? (sticky icky)
Instead of ITB's have you considered running a ported intake manifold and tb. they have some amazing results (pretty close to ITB's), and are dyno proven. It is alot cheaper than ITB's and not as much work to install and probably easier to tune. I'll try searching but if you get a chance search in the All Motor forum, they had a pretty good extensive thread discussing it and showing before and after graphs.
If you are set on going turbo, instead of changing some things on your block, why don't you consider selling your block and picking up another one and building it specificially for boost. It might be easier.
Ali
Old Aug 17, 2006 | 01:01 PM
PLAGUED_DB7's Avatar
Default Re: should i go itb's or turbo?? (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Instead of ITB's have you considered running a ported intake manifold and tb. they have some amazing results (pretty close to ITB's), and are dyno proven. It is alot cheaper than ITB's and not as much work to install and probably easier to tune. I'll try searching but if you get a chance search in the All Motor forum, they had a pretty good extensive thread discussing it and showing before and after graphs.
Ali</TD></TR></TABLE>
QFT
I have seen a few people jump up good amounts (5-25hp with tuning) by switching out IM's.
Old Aug 17, 2006 | 01:03 PM
Default Re: should i go itb's or turbo?? (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">
QFT
What does that stand for?
Ali
Old Aug 17, 2006 | 01:05 PM
Quoted for Truth
looks like something bad huh? Thats what I thought as well.
Old Aug 17, 2006 | 08:52 PM
Dartanian's Avatar
QFT
I have seen a few people jump up good amounts (5-25hp with tuning) by switching out IM's. </TD></TR></TABLE>
But a single throttle body will never have the incredible throttle response of properly tuned ITB's.
Old Aug 17, 2006 | 09:10 PM
aznvietboi87's Avatar
na = expensive and will never keep up with a fully build turbo which would cost less. turbo all the way!
Old Aug 17, 2006 | 09:18 PM
Sportyballade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I say get the ITB's and get that bitch tuned.
NA &gt; Turbo</TD></TR></TABLE>
screaming VTEC &gt; sissy turbo hiss
Old Aug 17, 2006 | 09:21 PM
Dartanian's Avatar
Default Re: should i go itb's or turbo?? (sportyballade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportyballade &raquo;</TD></TR><TR><TD CLASS="quote">
screaming VTEC &gt; sissy turbo hiss </TD></TR></TABLE>
This debate is so ******* stupid.
Old Aug 17, 2006 | 09:26 PM
lol i konw, its just opinion, because me, im perfectly fine with just gaining anyting over 200hp. having just 250 hp makes me happy enough ;] turbo isnt needed. i dont need to hit 300 hp
Old Aug 18, 2006 | 05:30 PM
atg1290's Avatar
Whatever you can afford FTW!!
Old Aug 18, 2006 | 05:33 PM
lVlemphizStylez's Avatar
Default Re: (aznvietboi87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznvietboi87 &raquo;</TD></TR><TR><TD CLASS="quote">na = expensive and will never keep up with a fully build turbo which would cost less. turbo all the way!</TD></TR></TABLE>
you have absolutely no clue about what youre saying
Old Aug 18, 2006 | 06:02 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
you have absolutely no clue about what youre saying</TD></TR></TABLE>
x2
217sportcompacts
Aug 26, 2010 01:02 PM
RACINTWEEK
Dec 30, 2004 12:57 PM
Scither69
Oct 27, 2004 04:59 PM
GSRacer
Jan 2, 2002 06:20 AM
