taillights question?
Old Aug 16, 2006 | 08:55 PM
sohcondis's Avatar
Default taillights question?
when i turn on taillights it wont work but when i brake all the taillights light up?
Old Aug 16, 2006 | 09:35 PM
RockWolf's Avatar
Default Re: taillights question? (4real)
the tail lights bulbs have 2 filaments. one for braking(bright light) one that open normaly(fade light)
Check if they have any filaments broken in them. normaly theres a black spot on the bulb like if it was burned. it may still work for braking since you shouldnt be using it as often .
Old Aug 16, 2006 | 10:15 PM
sohcondis's Avatar
Default Re: taillights question? (RockWolf)
the bulbs is new. **** i dunno when i turn on the lights still doesnt come on but when i brake they all light up. could it be from the front lights cause i dont have them in i only have the blinker ones in.
Old Aug 17, 2006 | 02:08 AM
Maldito X's Avatar
you might just have a loose connection, I had the same problem about 2 weeks ago, the brake lights would come on, but the regular lights didnt, so I went back there, opened the cap, played with the plug, and voila, they came on. That's probably what happened to you, especially if they were on before you switched the light bulbs, you probably left the plugs loose or something??
Old Aug 17, 2006 | 03:50 AM
ludesrv's Avatar
Tail light fuse.
Welcome to my under dash grounding problem. I pop those fuse on a regular basis. It's gay, but I'm fixing it soon. I beleive it's fuse #6 or #7, check the under dash fuse panel, it will point you in the right way. Also, while your at it, check all the fuses and make sure they are ok and the proper amp. Never, ever, put the wrong amp fuse in the fuse box, that's how you burn wires and blow relays and what not.
Old Aug 17, 2006 | 01:13 PM
sohcondis's Avatar
Default Re: (ludesrv)
thanks man i think it is a fuse cause my dash light for the speed etc.. doesnt come on too.
racerx413
Sep 20, 2014 02:38 AM
xjohnny817x
Aug 29, 2007 12:47 AM
thn116
Aug 12, 2007 07:14 PM
david90
Dec 9, 2003 04:13 PM
paulyman
Mar 31, 2002 06:56 PM
