Weird starting problem
Old Aug 16, 2006 | 07:46 PM
civickid03's Avatar
Default Weird starting problem
When cold the engine often "sputters" to life, usually after an extended cranking period (like 3-4 seconds after turning the key)....when the car starts the rpms slowly climb from what seems like 0 up to a rough 700-750 rpms, very slowly until the car sputters to life. I try not to give it too much gas because there's no oil pressure but if I do it right as it begins to fire on its own it starts up much better.
After idling a few moments the car idles stabily. When the car is warm it starts perfectly, without hesitation or sputter. Thanks.
Old Aug 16, 2006 | 08:19 PM
RCautoworks's Avatar
Default Re: Weird starting problem (civickid03)
Check your engine coolant temperature sensor, if its failing it could be giving the ecu the wrong signal at start up.
blackludebosh
Aug 8, 2008 10:37 PM
madball
12
Apr 2, 2007 05:10 PM
Cryptopsy
Aug 31, 2006 08:37 AM
Mike813
Jun 8, 2004 04:58 PM
Subzonic
Jun 23, 2003 08:16 AM
