? aboot turning it to a 5 lug thug
Old Aug 16, 2006 | 06:18 PM
R.Kelley's Avatar
Default ? aboot turning it to a 5 lug thug
ok i looked at the faq and im confused....can you do the 5 lug swap with just hubs in the front and hubs/bearings in the rear...are the calipers and brakets the same...ive got 00 Si brakes on my hatch right now
i obvi know that the rotors and wheels need to be changed...
thanks, Ryan
Old Aug 17, 2006 | 04:39 AM
PhatBoy5015's Avatar
Default Re: ? aboot turning it to a 5 lug thug (R.Kelley)
I'm not sure about the front, but on the rear you can just swap out the hub and spindle. But the problem is, you can't just buy the spindle from Honda. They only sell the whole trailing arm.
Old Aug 17, 2006 | 06:58 AM
lv6l's Avatar
my suggestion to you. buy the whole set. but make sure its 5 lug from a civic type R and not integra. that way you dont needt to have a headache when it comes to buying axles. your B series 32mm should fit up with the civic type r.
Old Aug 17, 2006 | 08:24 AM
R.Kelley's Avatar
what about when i need to buy new brakes? what rotors and pads would i use?
Old Aug 17, 2006 | 10:19 AM
chingpo05's Avatar
Default Re: (R.Kelley)
usdm type-r would do fine we did it to our friends ek9 and everthing bolted right up. u might need a porportional valve but we just adjusted the brakes under the dash. when u buy brake pads and rotors just buy it for the itr
u will need the brake cable too
Old Aug 17, 2006 | 10:22 AM
R.Kelley's Avatar
Default Re: (chingpo05)
will the Si cables work?
Old Aug 17, 2006 | 12:05 PM
lv6l's Avatar
if you're talking about the brake lines. no i dont think they'll work.
Old Aug 17, 2006 | 12:52 PM
Yes, the Si E-brake cable will work. So will any 92-95 Civics with rear disc. (i.e. 4DR EX, Si)
Old Aug 17, 2006 | 01:03 PM
R.Kelley's Avatar
thanks guys...now i just need to find a CTR setup
Old Aug 17, 2006 | 01:09 PM
ITR will work too.
Old Aug 17, 2006 | 01:13 PM
JDM-EJ698's Avatar
Default Re: (PhatBoy5015)
USDM ITR.
Old Aug 18, 2006 | 02:56 AM
lv6l's Avatar
ITR will work, but the axle for his motor wont work. CTR will work perfectly for him. CTR uses same axle as his, so he doesn't need to buy new axles.
Old Aug 18, 2006 | 06:28 AM
Default Re: (lv6l)
As long as its not JDM ITR, it will work. Only JDM ITR uses 36mm axles. USDM ITR's have 32mm like everything else.
Old Aug 18, 2006 | 07:54 AM
dthug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 &raquo;</TD></TR><TR><TD CLASS="quote">As long as its not JDM ITR, it will work. Only JDM ITR uses 36mm axles. USDM ITR's have 32mm like everything else.</TD></TR></TABLE>
very true just get either or and you'll be fine
Triker
Apr 10, 2012 12:57 PM
Mr.Quang
Mid-Atlantic (Sales)
Aug 6, 2011 09:42 AM
Rawl
Suspension & Brakes
Jan 31, 2010 08:55 PM
JDMorgan
Aug 4, 2005 04:27 AM
