D series Questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicaraguense13 »</TD></TR><TR><TD CLASS="quote"> 98 hatch flywheel clutch and Pressure plate fit a 89 crx D series single ??? </TD></TR></TABLE>
I'm a little confused on the question, if I udnerstand it correclty you want to use the flywheel, clutch and pressure plate from a 98 hatch on a 89 engine.
The pressure plate won't fit because the hydro trans shaft is bigger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 »</TD></TR><TR><TD CLASS="quote">I'm using the Z6 flywheel and clutch, including pressure plate, with an A6 tranny. Works just fine. It's the throw-out bearing that's different between hydro and cable transmissions.</TD></TR></TABLE>
Actually, for b series the pressure plates are different, maybe for d trans it does not matter
He's talking about D-Series. You can use a '92-'00 flywheel/clutch/pressure plate on '89-'91 with no problems. With '88 you have to use an '89-'91 transmission because the '88 has a different number of splines. The throw out bearings and release forks are completely different between the D cable and hydro transmissions. The difference in pressure plates with D cable and hyrdo is actually the flywheel having a larger diameter. So if you use a '92-'00 flywheel you have have to use a '92-'00 clutch/pressure plate.
crxblues
Jun 13, 2006 08:08 PM
SPOON_BeIgHtEeNsEe
11
Apr 9, 2004 07:10 PM
