Not going in gear
Old Aug 16, 2006 | 05:24 PM
97BB6Type-SH's Avatar
Default Not going in gear
i was planning on changing both the slave and master cylinder by friday but i guess it beat me to it....the gears were going in rough and/ or sumtimes not going in at first trys. but i tryed pulling out my house today and it doesnt go in any gear. i can turn it on fine and everything, guessing since its in neutral. but then i guess the problem wouldnt be the slave or master cylinder? can it be broken clutch spring retainers or transmission fluid needs to be changed? any help....thanks
Old Aug 16, 2006 | 05:51 PM
k_lude's Avatar
Default Re: Not going in gear (97BB6Type-SH)
totally the clutch...had the same exact thing happen to me..all springs jumped out. Broken pressure plate..get it fixed before it messes up your tranny. I got it fixed worked fine but it had after effects to my tranny. I left it for to long before i changed it. my recommendation change it as soon as possible.
Old Aug 16, 2006 | 06:03 PM
Default Re: Not going in gear (k_lude)
hmmmm i thought it was the clutch too when i saw it not going in nothing ..but jus went outside and cranked it up and goes in every gear and then starts acting up and making sum crackling noise....not grinding... so im still thinking slave cylinder and also my master cylinder fluid gets dirty like in 10 min. i put fresh clear brake fluid and drive it and turns blk and dirty, thats y im thinking its both the master cylinder and slave cuz right after i put fresh brake fluid in it the car feels perfect until it gets dirty like 10 min later....idk im not gonna drive it until i change the 2 cylinders and the tranny fluid and if it keeps on then ill have to change the clutch.... thanks
allmotorgsr98
Transmission & Drivetrain
12
Jun 5, 2011 10:25 PM
Laosakademiks
Sep 9, 2006 01:26 PM
517vwj_boi
Mar 14, 2006 09:35 PM
ludelvr
Sep 19, 2003 05:34 PM
