Ecu P73 OBD2B in a 00 GSR???
Old Aug 16, 2006 | 03:28 PM
RidingMark's Avatar
Default Ecu P73 OBD2B in a 00 GSR???
I have a question for all you guys, what would happen if I put a OBD2B ITR ECU in a 2000 GSR with a skunk2 IM. Cause right now, my vtec is messed up because of the stock GSR ecu and the new intake manifold. Instead of kickin in @ + - 6000rpm it pops in @ 4500rpm...
Old Aug 16, 2006 | 06:39 PM
Dartanian's Avatar
Default Re: Ecu P73 OBD2B in a 00 GSR??? (RidingMark)
It is supposed to engage at 4500 rpm.
A P28 chipped with a basemap would be cheaper and probably run better. The P73 has fuel maps, ignition curves, and vtec engagement optimized for a higher compression motor with more aggressive cams.
Old Aug 16, 2006 | 08:08 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidingMark &raquo;</TD></TR><TR><TD CLASS="quote">I have a question for all you guys, what would happen if I put a OBD2B ITR ECU in a 2000 GSR with a skunk2 IM. Cause right now, my vtec is messed up because of the stock GSR ecu and the new intake manifold. Instead of kickin in @ + - 6000rpm it pops in @ 4500rpm...</TD></TR></TABLE>
You wont be able to start it, youll need to get around the immobilizer first.
Get a VTEC controller.
Old Aug 17, 2006 | 03:22 PM
RidingMark's Avatar
Default Re: Ecu P73 OBD2B in a 00 GSR??? (ITR#132)
**** that's right heun! Was forgeting about that! THX!!! But...when I unplug my ECU to put the Boomslang wiring kit for the VAFC, will the immobilizer keep me from starting my car?
RiceOrRocket
Aug 28, 2007 09:13 PM
team 15
Jun 18, 2007 12:22 AM
nuklang
Oct 4, 2006 09:57 AM
Tex Blackwell
Jul 14, 2004 05:25 PM
smkngsr
Sep 8, 2002 12:00 PM
