my f22 build
Aright from what research I ve done here what I have.
I am going to run an f22 block from an 93 accord ex. I am going to put in a block gaurd, drop in some h22 forged pistons. I am having trouble with rods but I think. I am going to run eagle h beams from an h22 or h23. the last thing for my bottem end is to balance the assembly without the balancing shaft.
for the top end
I am going to use an h22 head with upgraded valves, retainers, and stage three cams. I am also going to port match the head. I havent fornd a intake manifold that I approve.
I need to know if this ideal works so any info can help.
for the top end
its a decent amount of work to put an h22 head on a f22 block. search and you should find some info about it though. a while ago someone did a sorta walkthrough on how to do it. if you search you will most likely find it.
