Noob Question : Airfilter
Old Aug 16, 2006 | 12:48 PM
Extreez's Avatar
Default Noob Question : Airfilter
Hi,
I see theres 2 types of airfilter
theres two types of airfilter which i dont know what the diffrences between the 2 are maybe u guys can help me out the pics are below of which im talking about
http://racingguys.onlinera.com/RedFilter.jpg
http://www.autotoys.com/pics/toucansf4001.jpg
i hear the 2nd one the foam filters u dont need to grease and clean ever is this true ? also gimmie whatever infos you guys have on the two and what u guys prefer
Old Aug 16, 2006 | 12:53 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Foam filters don't filter as well (doesn't stop as much junk) as the oiled cotton filters do.
Old Aug 16, 2006 | 01:22 PM
Extreez's Avatar
Default Re: (PatrickGSR94)
oh forsure then its the oiled cotton filters im getting, is there any risk of engines life with putting the medal piping instead of rubber and do cotton filters hold out all dirt ? or somewhat just more then foams ?
Old Aug 16, 2006 | 01:46 PM
davidluko's Avatar
The metal vs. rubber pipping won't affect anything. What I'd suggest is to get a K&N cone filter. Most filters from those cheap 'performance' brands like Ractive are junk and filter and flow like crap. The foam filters usually flow better than cotton filters but like the first guy said, they don't filter out as much dirt and I've also heard some people say that over time the foam can start to crumble or whatever and get pieces sucked into the engine.
Old Aug 16, 2006 | 01:49 PM
Extreez's Avatar
Default Re: (Hatch_R)
K&N doesnt give sound though huh ? i will probably use the rubber piping its best to stay safe and use what they give you ahha, do you guys think i should put a cover over the airfilter i buy im not all about performance here i jstu wanna get a lil better sound then the stock.
Old Aug 16, 2006 | 01:51 PM
Solscud007's Avatar
there is a lot of who is better than who in terms of filters. K&N is good. so is AEM. but after I saw this and ran an Apexi filter I was hooked. I would try them out if you can afford it. I have tried AEM and an HKS foam filter not a whole lot happens.
http://www.daliracing.com/v666...t.cfm
Old Aug 16, 2006 | 02:06 PM
davidluko's Avatar
Any cone filter will sound louder than stock. If you're just looking for louder soud, then you can do it for free by removing the stock airbox and just leaving the stock filter and stock pipe (the stock filter is actually a cone filter). It sounds nice and doesn't whistle (only sometimes a tiny bit, really quietly) like the aftermarket cone filters do.
About what Solscud007 said, AEM used to use K&N filters when they were a new company. Now that they have gained a good reputation and everything, they have switched over to some cheaper filter which I heard is crappy, but that's not from experience so I don't really know, just saying what I heard.
You don't have to worry about anything happening by switching your stock piping out for an aftermarket metal pipe. It'll give you better flow, and be louder which is what you said you want.
Old Aug 16, 2006 | 02:23 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">Any cone filter will sound louder than stock. If you're just looking for louder soud, then you can do it for free by removing the stock airbox and just leaving the stock filter and stock pipe (the stock filter is actually a cone filter). It sounds nice and doesn't whistle (only sometimes a tiny bit, really quietly) like the aftermarket cone filters do.
You don't have to worry about anything happening by switching your stock piping out for an aftermarket metal pipe. It'll give you better flow, and be louder which is what you said you want.</TD></TR></TABLE>
I just wanted to add, its not the filter that whistles. Its the throttle body at partial opening, and the airflow across it is what whistles. Whether or not the intake and filter block out that sound would entirely depend on size, material, and shape, but the sound is always present even if you can't hear it.
To the original poster, don't pay attention to the horsepower claims, especially with tests showing filters within a couple of hp or each other. You can get 5% differences between dyno runs on the same car under identical conditions, so a 1 hp difference between filters is meaningless dyno variance. What the tests don't measure, is the transient throttle responce improvements that a good filter and less restrictive intake provides.
I personally use a K&N (older AEM CAI came with it), and I trust K&N to release a quality product.
Old Aug 16, 2006 | 02:55 PM
Extreez's Avatar
Default Re: (TunerN00b)
can u guys tell me a good airfilter which i should be looking forward to buy im gonna look forward to K&N's but i was hoping something not TOO pricy but still safe and good, dont know if theres any which would be not too pricy but also still safe and good. You guys know of any ?
actually im not sure how much K&Ns go for
Old Aug 16, 2006 | 10:26 PM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I just wanted to add, its not the filter that whistles. Its the throttle body at partial opening, and the airflow across it is what whistles. Whether or not the intake and filter block out that sound would entirely depend on size, material, and shape, but the sound is always present even if you can't hear it.</TD></TR></TABLE>
Hmm I never knew that. When I had the stock filter on the stock intake arm I could barely if at all ever hear it whistle and now that I have a K&N cone filter on that same stock intake arm, it whistles pretty loud. I don't see how that'd work if it was just the throttle body? I don't think the filter can quiet it down that much.
Also about the K&N price, you should be able to get one for around $40 or $45.
Old Aug 16, 2006 | 10:33 PM
DPSJosh's Avatar
My intake actually whistled at the airbox on my 02 monte carlo. The K&N Kit came with a gasket for the airbox but I didn't use it.
I've heard of and seen alot of problems with K&N Filters on MAF cars because people tend to over oil them and the oil gets caked in the MAF. I've used K&N's in all my cars and will always use them. WHen they get dirty just get a filtercharger kit and clean em out.
For K&N!
Old Aug 16, 2006 | 10:45 PM
Extreez's Avatar
Default Re: (DPSJosh)
yea ill get the K&N Cone Filter forsure what do u guys suggest stock piping or the medal ones, im not about performance more about noise but WAY more about the safety of my cars motor i dont wanna force anything dont wanna take any risks AT ALL, is there any risk on the medal piping at all ? or anything
Old Aug 17, 2006 | 12:21 AM
Extreez's Avatar
Default Re: Noob Question : Airfilter (Extreez)
what about these filters what do u guys think does it give loud sound ? should i buy or no ?
http://cgi.ebay.com/ebaymotors...sting
Old Aug 17, 2006 | 05:00 AM
DPSJosh's Avatar
Metal pipes will give you the louder noise by far. On the downside they get pretty hot and can heat up the incoming air a tad.
Old Aug 17, 2006 | 09:53 AM
Extreez's Avatar
Default Re: Noob Question : Airfilter (DPSJosh)
so not the best thing do use a medal piping huh ?
Old Aug 17, 2006 | 01:18 PM
Extreez's Avatar
the reason im saying not best thing to do medal piping is heat huh ? or is it completely safe and non of u guys have gotten any problems ?
Old Aug 17, 2006 | 01:29 PM
PLAGUED_DB7's Avatar
I am running the foam HKS filter and its ehh'
Old Aug 17, 2006 | 01:49 PM
Community Builder
This is how I run, normally with the airbox lid in place, just had it off to show the filter
Been running the same K&N air filter since 2001, since before I even joined H-T
Old Aug 17, 2006 | 03:51 PM
rgaray's Avatar
Check out this site.
http://www.bobistheoilguy.com/...1.htm
Old Aug 17, 2006 | 06:04 PM
mrdeadman's Avatar
They let me pick
I have a comptech filter. I clean it every oil change. 3-4k miles. I trust it more than K&N. My dirt bike has a foam filter almost identical and it has a way more performance oriented engine-13500 rpm and I ride it in the dirt so I figure if it keeps the dirt out of a dirt bike then it can do just as good of a job for a car.
Old Aug 18, 2006 | 12:20 AM
Extreez's Avatar
hey patrickgsr when u put the lid on do u see a big performance and sound diffrence without it ?
Old Aug 18, 2006 | 04:45 AM
mrdeadman's Avatar
They let me pick
Default Re: (Extreez)
I know you were refering to mrpatrick but, I do it now. There is not really a performance difference maybe a slight gain in the upper range. The sound is the most notable... loud...throaty...deep sound.
Old Aug 18, 2006 | 10:50 AM
Extreez's Avatar
Default Re: (mrdeadman)
so it sounds better with it on ?
Old Aug 18, 2006 | 01:12 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez &raquo;</TD></TR><TR><TD CLASS="quote">so it sounds better with it on ?</TD></TR></TABLE>
It depends on your tastes... I like it either way.
Mandark06
Apr 17, 2007 07:23 AM
ck123
Jul 5, 2006 10:13 PM
cats_on_ice
Apr 22, 2006 06:45 AM
VTECisSeXY
Jul 17, 2004 12:04 PM
