95 Accord, Jdm H22a W/ Skunk2 Intake,
I have a 95 accord lx with a 94 jdm h22a motor swap. I installed a skunk2 intake manifold before i dropped it in. the problems im having are to do with intake accesories. #1. There is NO where to put my Intake Air Bypass on the skunk2. I have a p72 ecu and i know it does not read a knock sensor but will it read the IAB? I also have taken off the whole egr setup cause i was also told that the p72 didnt read that also. If there is anyone out there that has ran into this problem or knows a way arround it please help. also my accord came with an external coil and i reused it for the prelude motor. will there be any problems with the ecu reading an external coil rather than an internal coil? Please help. Thanks
umm teh skunk 2 manifold doesnt use the IAB since its a single stage manifold. therefore you remove the IAB....the IAB is NOT an emissions deivce therefore it will not have a check engine light.
the p72 DOES read a knock sensor. if its missing then it will throw a code 23.
a coil is a coil....it doesnt matter if its in the distributor, on the engine or in your butt, as long as it is wired it should work.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">umm teh skunk 2 manifold doesnt use the IAB since its a single stage manifold. therefore you remove the IAB....the IAB is NOT an emissions deivce therefore it will not have a check engine light.
a coil is a coil....it doesnt matter if its in the distributor, on the engine or in your butt, as long as it is wired it should work.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">ahh, the almighty coil-in-*** conversion
lmfao, only on HT!
</TD></TR></TABLE>lmfao, only on HT!
And does the p72 read and egr sensors? I have this motor all finished and it wont start for me. It just turns over strong. I also found the pinout for the p72 and the knock sensor location is empty. Should i wire it up anyway?
VisualAutoMotoring
Aug 3, 2004 02:46 PM
se93
Jun 3, 2002 10:47 PM
