95 Accord EX problem..... :(
Old Aug 16, 2006 | 05:12 AM
o0adam0o's Avatar
Default 95 Accord EX problem..... :(
On my way home from work monday around 4pm i was on the highway and noticed all my dashboard needles dropped and went back up.....it did this about 3-4 times while drivving. Then they all fell again but this time the car engine cut off. I pulled over to the side and it took 4-5 tries to get the car started again.
It worked fine when i went to the gym later that night and wordked fine all yesterday up untill i headed home from work. I noticed the same thing was happening with the needles dropping and jumping back up, once again the car turned off. I pulled to the side and tried for like 45min and the car wouldnt start. I had to get it towed home.
So when i turn the key the starter works and the engine seems to turn on for like a second and then cut off. If i push in the gas pedal for that one second that is on, the engine revs and cuts off immediatley.
One final thing i noticed is the ignition. Usually when i turn the key to liek the third position i can get the stereo and A/C to turn on and leave it in that position. Now in that same key position nothing happens. I can push the ignition a little further and all that cuts on, but i have to be holding it.
Any help is deeply appreciated. Im without my car for now...
-Adam
protheos
Nov 21, 2025 02:07 PM
joc1394
Feb 18, 2008 12:31 PM
fleetmack
Nov 5, 2007 09:03 PM
LordoftheAccord
May 23, 2003 06:11 PM
