accord swap?
Hey can anyone help out? or do you recoment to go with a rebuilt stock motor ? Whould I be able to use my stock axels if I go with my swap or would I need 97 axels?
well it will bolt right up but the ports on the intake are smaller on the 5th gen accord heads as the 4th heads but it will still work. But the water pipe under the egr valve is different it is not as big and it is moved over to the sideif you get the 97 accord im gasket it should work if you bolt down tight
can you guys give me a parts list of the thing i should get and name brand and were to get them and how much i should pay so i dong get jiped. im going with the stock motor rebuilt with the piston upgrade and the f23 intake i think how much should i pay for that thanks in advance guys
90coupekami
Sep 23, 2012 11:22 AM
Ezekielskate315
Jul 6, 2009 10:17 AM
maxt
Mar 21, 2005 05:45 PM
most definally
