P28 Datalogging.... possible through DLC Connector with stock chip?
Old Aug 15, 2006 | 07:48 PM
tekcivic's Avatar
Default P28 Datalogging.... possible through DLC Connector with stock chip?
Hoping someone can help answer a question for me.
I have a stock p28 honda obd1 ecu. I'm wanting to do a bit of datalogging before actually chipping the ecu and purchasing a rom burner. Does anyone know if it is possible to datalog with a stock chip using the dlc connector? I saw a small post about the connector on PGMFI.ORG but it doesnt say much. Anyone have any experience with this?
Thanks
Tek
Old Aug 15, 2006 | 11:09 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: P28 Datalogging.... possible through DLC Connector with stock chip? (tekcivic)
In theory, yes, but with Crome at least, you have to load datalogging software onto the ROM so it can read the information... so you will probably need to chip it first.
Old Aug 16, 2006 | 01:58 AM
mtber's Avatar
Default Re: P28 Datalogging.... possible through DLC Connector with stock chip? (JDM_Ej)
No it is not. You need to have quick datalogger + rtp plugins on the eprom you are running in order for crome's datalogging features to work.
You also need to remove rp12 on the ecu.
Old Aug 17, 2006 | 03:19 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: P28 Datalogging.... possible through DLC Connector with stock chip? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">No it is not. You need to have quick datalogger + rtp plugins on the eprom you are running in order for crome's datalogging features to work.
You also need to remove rp12 on the ecu.</TD></TR></TABLE>
You mean J12? I thought that was only required for Uberdata?
gsrhatch95
Aug 30, 2007 06:17 PM
dizzyroc88
10
Mar 22, 2007 05:32 PM
tekcivic
Aug 17, 2006 07:58 AM
B16aSir2
Jan 22, 2006 06:28 PM
HOND PWR
Jul 22, 2003 05:44 AM
