1994 accord LX has problems
Old Aug 15, 2006 | 07:17 PM
wingback44's Avatar
Default 1994 accord LX has problems
I was changing the spark plugs on my 94 Lx when i noticed that 3 of the 4 plugs had oil all over the threads. Only one of the plugs didn't. Just wondering what might cause this. Also, my brake fluid has started looking brown as of late and my brakes have become somewhat mushy, any ideas on either of these problems would be appreciated.
Old Aug 15, 2006 | 09:37 PM
Homesickelian's Avatar
Default Re: 1994 accord LX has problems (wingback44)
A possibility is a leaky valve cover gasket leaking into your spark plug cylinder and then down, and will eventually make a pool. That might not be the issue but is a potential to throw out there. If it's not it will be a more difficult issue..
Also I thought it would be nice to bump the thread..
Old Aug 16, 2006 | 01:51 AM
YeuEmMaiMai's Avatar
since you will have to replace your tube seals to solve this problem, you might as well buy the whole kit and replace all of the neoprine rubber parts
Old Aug 16, 2006 | 02:16 PM
loup05's Avatar
Default Re: 1994 accord LX has problems (YeuEmMaiMai)
what parts r those?
Old Aug 16, 2006 | 02:20 PM
Seeds's Avatar
Default Re: 1994 accord LX has problems (loup05)
valve cover gaskets... you can buy a kit at autozone, orilieys, where ever, for like $20. Be carefull putting the valve cover back on, those studs dont take a whole lot of torque, I have broken a few... there like $7 at honda, but they have order them.
Old Aug 16, 2006 | 04:27 PM
Dave421's Avatar
that's your problem with the spark plugs.
as for your brakes, brake fluid is like your oil, it requires changing periodically. It becomes contaminated and over time water & air will get in it. That will reduce your pedal feel since air compresses much easier than brake fluid so you have to press the pedal harder to get the same amount of braking at the calipers.
Old Aug 16, 2006 | 05:15 PM
wingback44's Avatar
Default Re: (Dave421)
thanks for the input guys, i appreciate it. i think il go to autozone after work and see about getting a valve cover gasket kit.
preludebro
May 1, 2011 09:39 AM
rebeltshead
Dec 29, 2008 03:03 PM
grlstockb18c1
Jun 11, 2003 06:32 PM
LegendKing
Aug 8, 2002 08:16 PM
wales78
Jul 10, 2002 05:12 AM
