Muffler/exhaust removal
Old Apr 25, 2002 | 11:45 AM
Weston's Avatar
Default Muffler/exhaust removal
Well, I got my ITR muffler today, the b-pipe should get here later today or tomorrow... I have to go to work in a little bit, so I was just going to put on the ITR muffler real quick, but I ran into a problem... how the hell do you remove those nuts with the springs on them!? Those things like refused to turn, and every time I pushed on it, the entire exahust system moved and most of the force I was applying was asorbed by that.
I'm thinking I'll just wait until the b-pipe gets here and then do everything at once (or be lazy and just go across the street to Midas). But, I still need to know how to get those bolts off so I can seperate my stock muffler and b-pipe. Thanks!
Old Apr 25, 2002 | 11:48 AM
garados's Avatar
Default Re: Muffler/exhaust removal (Weston)
Get two wrenches, one for the bolt, one for the nut. Also, get some of that spray that loosens up rusted and siezed bolts. Also, don't force it, just use a bigger wrench
Old Apr 25, 2002 | 12:13 PM
vtec_addict's Avatar
Default Re: Muffler/exhaust removal (garados)
If you know some one with an impact. thats the easiest way to break them free..
Old Apr 25, 2002 | 01:50 PM
ndustryalGSR's Avatar
Default Re: Muffler/exhaust removal (vtec_addict)
Spray it down with penetrant. Wait a little while. Try again. Use a longer wrench, for leverage, a breaker bar (if there's room under there), or tap the wrench with a hammer/mallet to get the bolt started.
Good luck. These methods have always worked for me.
Old Apr 25, 2002 | 01:56 PM
whtrice01gsr's Avatar
Default Re: Muffler/exhaust removal (ndustryalGSR)
LIQUID WRENCH!!!!!!!!!! good luck
Old Apr 25, 2002 | 02:09 PM
LOwrestling2001's Avatar
Default Re: Muffler/exhaust removal (whtrice01gsr)
u dont need any penetrator on spring bolts they don't get rusted like the Bpipe bolts. chances are ur just not using a tool w enuf leverage. just get a longass ratchet or breaker bar.
Old Apr 25, 2002 | 04:48 PM
eargrub's Avatar
Default Re: Muffler/exhaust removal (LOwrestling2001)
if you take a close look, the nuts are welded on at the b-pipe/muffler connection. all you need to do is turn the bolt with the spring on it and it will come right out.
Old Apr 25, 2002 | 06:26 PM
Weston's Avatar
Default Re: Muffler/exhaust removal (eargrub)
Ok, I'll give that another try... I mostly just wanted to make sure there wasn't something special I had to do for those springs. I'll probably just take the stock b-pipe and muffler off the car together and then seperate them; that way seems a lot easier. Now if UPS would just deliver my ITR b-pipe... It's been "out for delivery" since 6:30am and it's now 8:30pm. I don't think I'll see it tonight. Does UPS do something different for delivering large awkward packages like that?
Old Apr 25, 2002 | 06:29 PM
Red2001GSR's Avatar
New User
to get my muffler off...
I put a wrench on there... almost broke my arm trying to break the bolt loose...
got mad, and beat the wrench with a hammer.
It worked wonderfully.
Old Apr 25, 2002 | 07:31 PM
OneThirtyEight's Avatar
Default Re: Muffler/exhaust removal (Red2001GSR)
Just use a torch on the bolts on the cat, u can juse use those cheap yellow MAPP gas tanks with the nozzle on em. Works wonders.
Old Apr 25, 2002 | 08:31 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Muffler/exhaust removal (97blackteg)
I used a rubber mallet and hit the wrench
Spazbaboon
Dec 28, 2006 01:11 PM
totsie7944
Oct 25, 2006 12:35 PM
digitalh3lix
Nov 21, 2004 06:35 AM
Alexander
Mar 25, 2004 05:31 PM
droppedcivo
Apr 22, 2003 09:53 PM
