B18c1 (gsr) obd2 intake manifold on B18c1 (gsr) obd1 head
Question is will an b18c1 obd2 intake manifold work on a b18c1 obd1 head? I have an obd2a car (99 gsr), I can find many 94-95 heads and i have a obd2 intake manifold. I just wanna make sure that I won't have any issues as long as i use the obd2 intake cause i dont wanna convert obd2- obd1...
placements of evap and certain sensors will be off a lil bit... everything will still work as long as you take the time to make it work.
*the mani should bolt right up. or in your case, the head.
I put an OBD II IM on my OBD I GSR, like he said the sensor placement for the evap is slightly different (mine got zip tied up) and there is one coolant line that goes into the IM that will have to be split in somewhere else (I just T'd into the coolant line for the IACV).
