drag radials
Remember, the best size depends not only on the wheel size, but also on the car; I assume you are asking for a 1994 Accord. Ideally, for that car, you would want 205/45-17, but I don't know of any drag radials that size. The BFG comes in 205/40-17 (which is about 3 percent smaller in diameter than stock) and 225/45-17 (3 percent larger). Either could be mounted on a 17x7 rim, but I don't know which would be better. Maybe someone else here does; if not, you might also try asking in the drag racing forum.
