The Five Steps to Diagnosis
Old Aug 15, 2006 | 01:52 PM
themilman's Avatar
Default The Five Steps to Diagnosis
Step 1. List your car details: 91 Integra, 155k (after searching of course)
Step 2. List you car mods: 8lb Lightened Flywheel, AEM FPR, BLOX IM, MSD Wires/Cap/External Coil, JG Bored 62mm TB
Step 3. List your problem: Car occasionally stalls when engaging the clutch (coming to a stop). Idle is 800rpm but rough. Car restarts fine after stalls, has no other problems, no power loss, no stuttering, nothing.
Step 4. List what you have checked to date: No codes are being generated by the ECU. Grounds are solid. No vacuum leaks detected. Recently cleaned IACV. Injectors, cap, rotor, plugs are all new. My theories include: bad MAP or TPS sensors (do not know how to test), bad dashpot, bad ground or positive battery connection, bad fuel relay, sticking IACV?
Step 5. You the reader respond with your theory, idea, and method of testing for my problem
Old Aug 15, 2006 | 03:49 PM
non-VTEC's Avatar
Default Re: The Five Steps to Diagnosis (themilman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themilman &raquo;</TD></TR><TR><TD CLASS="quote"> 8lb Lightened Flywheel
that will do it......i had/have the same issue. the ECU can't compensate for the fast drop of engine idle speed when coming to a stop so it stalls out.
the fix: have your engine idle speed raised a little. open up the idle scew on the throttle body. if that does not work then you need to have the ECU re-chipped and have the moving idle speed modified/adjusted.
Old Aug 16, 2006 | 08:37 AM
themilman's Avatar
Thanks, but thats not the problem. I had the lightened flywheel installed for 1yr BEFORE this problem started. Yes, every blue moon the car would stall because of the flywheel, but now it stalls all the time, and idles rough. Its not the flywheel, its something additional. But having the flywheel doesn't help the problem it aggrevates it. I'd like to solve the issue before i just raise the idle speed.
Old Aug 17, 2006 | 08:57 AM
themilman's Avatar
bump for help
Old Aug 17, 2006 | 10:19 AM
IHTFP's Avatar
step 6: do you have a helms manual??
Old Sep 4, 2006 | 01:49 PM
themilman's Avatar
Yes.
LST2
Jul 28, 2008 06:05 PM
themilman
Sep 10, 2006 03:28 PM
themilman
Aug 15, 2006 01:54 PM
DarkBB4
Dec 7, 2004 06:30 PM
servion
Jul 22, 2002 07:47 AM
