FT/FS: 350Z top of line Track Edition! Cali
Old Aug 15, 2006 | 01:44 PM
bluesaint's Avatar
Default FT/FS: 350Z top of line Track Edition! Cali
FS: 21500, FT: i need to get at least 15k back, so let me know what you have.
Engine:
VQ35DE - 3.5 Liter DOHC 24 Valve V6 Aluminium-alloy engine with CVTCS
287HP @ 6,200rpm
274 lb-ft Torque @ 4,800rpm
Displacement - 3498 cc/213 cu. in.
Bore and Stroke - 95.5 mm and 81.4 mm
Compression ratio - 10.3:1
Equal Length headers with ceramic coating
Iridium Sparkplugs
Balanced aluminium lightweight crank pulley
Balanced aluminium lightweight accecessory pullies
High temperature silicon radiator hoses
Gas Milage 20/26
Drivetrain
Longitudinally mid-mounted front engine/rear-wheel drive
Carbon-fiber composite driveshaft
Six-Speed close-ratio manual transmission
Viscous limited-slip differential
Traction Control System
Vehicle Dynamic Control
Wheels and Tires
18 inch Rays super-lightweight 6-spoke forged-alloy wheels
Bridgestone RE050A Maximum traction tires
Brakes
Brembo braking system - 4 piston caliper with 12.8 x 1.18 vented front discs and 2-piston caliper with 12.7x0.87 vented rear discs
Goodridge Stainless Steel Mesh brake lines on all 4 calipers
4-wheel Anti-lock Braking System (ABS), Electronic force Distribution (EBD), Brake Assist (BA)
Suspension
Front: Independent 3-link aluminum-alloy suspension with hollow stabilizer bar and strut bar
Rear: Independent 4-link aluminum-alloy suspension with hollow stabilizer bar, strut brace and aluminum-alloy subframe Ripple-control shock absorbers
Engine speed-sensitive power-assisted rack-and-pinion steering
Aerodynamics
Comprehensive underbody airflow management
Front: Zero-lift
Rear: Zero-lift includes front chain spoiler, rear underbody diffusers and rear spoiler
Drag coefficient (Cd): .29
Features-Exterior
High Intensity Discharge (HID) xenon headlights
Dual exhaust tip system
Dual power outside mirrors
Aluminum hood
One-touch rear hatch/trunk release
Carbon Fiber Composite air duct
UV-reducing solar glass
Audio System
160-watt audio system with AM/FM/CD (including CDR)
MB Quartz and JBL Speakers
Interior
Automatic Temperature Control (ATC)
3-bay gauge cluster (trip computer, oil pressure and voltmeter)
Trip computer with multiple functions
Shift up indicator light
Power windows with one-touch auto-up/down feature
Power door locks and remote keyless entry
Remote front windows down and hatch/trunk release>/li>
Key-operated front windows up/down
Cross-drilled aluminum pedals
Cruise control and HomeLink Universal Transceiver
Overhead sunglasses storage
Tilt steering column with integrated gauges
Variable intermittent windshield wipers with built in washer
Auto-Dimming rearview mirror
Dual illuminated visor vanity mirrors
Digital clock (in radio)
Two 12-volt DC power outlets (front and rear)
Cup holders (3)
Safety
Dual-stage supplemental front airbags with seat belt sensors
3-point ALR/ELR passenger seat belt system
Seat belts with pretensioners and load limiters
Total 6 airbags (2 front, 2 head column, 2 side)
Energy-absorbing steering column
Zone body construction with front and rear crumple zones
Hood buckling creases
Pipe-style steel side-door guard beams
Nissan Vehicle Immobilizer System
Vehicle security system
Vehicle Detail Info
2003
Clean Title Vehicle with Title on Hand (no holds, leins, etc)
40,000 Miles of Gentle commute miles
Powertrain warranty transfferable to new owner
jdm_ftp
Mid-Atlantic (Sales)
Jun 28, 2011 05:03 PM
BowDownCRX
May 4, 2010 12:22 PM
JeffS
Jan 23, 2002 09:34 AM
