Vacuum Canister thing
Old Aug 15, 2006 | 12:39 PM
huviduc's Avatar
Default Vacuum Canister thing
i cant remember the name of it exactly, but i was wondering if it necassary to keep the canister that is attached to the vaccum lines that sits below and to the right of the battery. i have a JG intake manifold and Golden eagle vacuum manifold if that matters. i was going to take it out but wanted to check first. thanks
Old Aug 15, 2006 | 12:57 PM
SmogKing's Avatar
Default Re: Vacuum Canister thing (huviduc)
It's required if your state require a emissions test. I personally would not remove that system
Old Aug 15, 2006 | 01:00 PM
gabebauman's Avatar
Default Re: Vacuum Canister thing (SmoGuy)
Charcoal Canister?
Old Aug 17, 2006 | 07:47 AM
huviduc's Avatar
If it is only required for emission tests then i am going to go ahead and remove it because i am not reguired to pass emissions and if i am at some point, i acan put it back in. Does anyone else no for sure if i can take it out? i always see all these wire tucked and shaved bays and that thing is no where in sight and i highly doubt that you guys take the time to relocate that, correct me if im wrong. thanks guys
Old Aug 17, 2006 | 04:40 PM
ci_v_ic's Avatar
Default Re: (huviduc)
free bump for this post b/c i also wanna know if this absolutely has to be "hooked up"
Old Aug 17, 2006 | 05:45 PM
yesSIR-S's Avatar
Default Re: (ci_v_ic)
http://www.clubcivic.com/board...58595
Old Aug 17, 2006 | 06:06 PM
DrVtec99's Avatar
I took all of my evap **** off my 99 si
Notmyusername
41
Nov 12, 2020 12:59 PM
timtiminy
Feb 7, 2013 02:28 AM
dkrex001
Sep 27, 2006 11:03 AM
87cvicdx
Jun 6, 2004 03:30 PM
tiresmoke
Apr 19, 2004 05:45 AM
