*****FS: 98 Civic DX Coupe $5400 2 week special!!! *****
Ready to sell it... Title in hand
special deal for 1 week only then the price will go back up..
$5200!!!
Buyer will not get Takata that is shown!
Here's some info:
1998 Civic DX Coupe
Sohc, 102k, 5sp, NO A/C
Ext:
Very clean, NO RUST anywhere, no major dents just small door dings
SiR Bumpers (OEM)
SiR Lip (OEM)
SiR Headlights with City Lights (OEM)
CTR Thin Side Moldings
CTR Folding Mirrors
CTR Front Grill (OEM)
99-00 Tails
NEW OEM CGP hood
OEM Antenna block off plate
Small Scrapes on the front bumper longest is an inch
Int:
Very Clean
GUTTED! (No rear panels, no carpet, no radio) Have EVERYTHING still
Spoon Aluminum Shift ****
Buddy Club Quick Shifter
SRR 4pt. Harness
Integra Type-R Shift boot (red stitching)
Autopower 4pt. rollbar with diag. bar, harness bar and headbar. (Painted CGP)
I/O Rollbar Foam Padding
Radio Block Off (OEM)
Amber cluster/climate control
Mild rear wiretuck
Removed SRS system (everything)
Polished Items
Eng:
Sohc, non-vtec
New OEM Plugs
New OEM Wires
ES Shifter Bushings
Spoon Res. Covers
Honda filters used
mobile1 synthetic
Runs great, no problems
Mild Wire Tuck
Many unneeded and ugly brackets removed too.
Susp:
Buddy Club N+ Full Coilovers
Function7 LCA's
ASR Brace (Polished)
SRR Rear Camber Arms
SRR Rear Toe Adjuster Arms
Mugen Trailing Arm Bushings
New OEM Suspension Hardware (every bolt in the rear was replaced)
OEM Replacement Front Rotors
OEM Replacement Front Pads
OEM Rebuilt Calipers (both fronts)
Civic Si wheels
Muteki Open End Lug Nuts
Dunlop SP Sport FM901's (195/55/15) NEW!
Maint: Within the last 2000 miles
Replaced Axles
Water Pump
Timing Belt
Drum Rebuild kit
Flushed Brake Fluid
Some Pics:
Modified by DXkid888 at 7:39 PM 8/16/2006
$5200!!!
Here's some info:
1998 Civic DX Coupe
Ext:
SiR Bumpers (OEM)
SiR Lip (OEM)
CTR Folding Mirrors
99-00 Tails
NEW OEM CGP hood
Int:
Very Clean
SRR 4pt. Harness
Mild rear wiretuck
Polished Items
Eng:
Sohc, non-vtec
New OEM Plugs
New OEM Wires
ES Shifter Bushings
Spoon Res. Covers
Honda filters used
mobile1 synthetic
Mild Wire Tuck
Susp:
Function7 LCA's
Civic Si wheels
Replaced Axles
Water Pump
Timing Belt
Drum Rebuild kit
Flushed Brake Fluid
Some Pics:
Chester Rumble
Nov 10, 2008 10:29 AM
MidwestSiR
Oct 4, 2007 10:04 AM
MidwestSiR
May 11, 2007 06:38 PM
