PULLEY KIT
Old Aug 15, 2006 | 12:09 PM
RSXTYPES0818's Avatar
Default PULLEY KIT
Does anybody know about the aem pulley kit for the rsx is a apin to put on or is it worth it.
Old Aug 15, 2006 | 12:44 PM
Default Re: PULLEY KIT (RSXTYPES0818)
what i ment to say is it a pain to put on the car and does it really make a difference.
Old Aug 15, 2006 | 04:56 PM
jabrun31's Avatar
its a pain to put on but it is def worht it. i wouldve gotten it a while agoo but since i ave a sub in the trunk the pulleys would end up making my amp lose power and therefore rendering the sub useless. if i didnt have a sub, id def get them
Old Aug 22, 2006 | 02:11 PM
MyK20Rips!'s Avatar
Default Re: (jabrun31)
there a pretty big ******* pain to install. helped my friend put them on his 03 type-s. if your trying to waste a day , and waste 165 bucks, defitnely go for it. its not gonna make that much of a difference. stock acura pulleys are pretty well off.
Old Aug 22, 2006 | 04:07 PM
maxspeedhonda's Avatar
Default Re: (MyK20Rips!)
I wouldn't waste your time/money, not to mention screwing the the harmonics of the motor. If anything, maybe just do the accessories, I would leave the crank alone.
Old Aug 22, 2006 | 06:45 PM
ScuDC5's Avatar
Default Re: (maxspeedhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxspeedhonda &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't waste your time/money, not to mention screwing the the harmonics of the motor. If anything, maybe just do the accessories, I would leave the crank alone.</TD></TR></TABLE>
The K20 doesn't have a harmonic sensor by the way, so you won't mess it up that way. older cars do though.
there is a long long thread on ClubRSX about the AEM pulleys and the damage some people have had from them. I highly reccomend you head over there and do a search for it and read through it. Basically, people say to go with UR instead of AEM.
Old Aug 22, 2006 | 07:19 PM
Default Re: (ScuDC5)
I wasn't really referring to a sensor. The crank comes balanced perfectly from honda with the stock crank pulley. If the crank pulley is not balanced perfectly (which most cheap aftermarket ones are not) then you send vibrations through the crank. This could lead to you breaking oil pump gears and wrecking a motor, which is why I run a ATI dampener. 9 out of 10 reputable engine builders will tell you this, hell, drop earl a pm and see what he has to say about it.
blackh23
Nov 19, 2007 09:09 PM
NA4sho
Honda Civic (2006 - 2015)
Oct 21, 2006 08:26 PM
mrnice1058
21
Nov 8, 2004 05:49 AM
gen4h22a
Oct 13, 2003 10:31 AM
type-si
May 7, 2003 09:31 PM
