Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 CRV Rear Differential Leaking
Old Aug 15, 2006 | 12:06 PM
barga's Avatar
Default 2001 CRV Rear Differential Leaking
I have a 2001 CRV with only 23K miles on it (believe it or not!). It appears that the rear differential is leaking fluid.
I don't see leaking near the axles (rubber boots). It looks like the differential housing is 3 pieces (front, middle, back), and its leaking in the 2 areas where these 3 pieces are bolted together. My question is this: Are there seals (gaskets?) where these pieces are joined? I don't see any indication of seals from the outside of the differential.
Old Aug 16, 2006 | 03:57 AM
elise's Avatar
Default Re: 2001 CRV Rear Differential Leaking (barga)
thats odd. havent seen that happen before. (yet)
I know axle seals go bad now and then but..
Clean it off real good with brake clean. and monitor closely.. hopefully you can pin point it.
not sure if the image works
goto hondaautomotiveparts.com for a better description
hope you figure it out!
Old Aug 17, 2006 | 08:32 AM
barga's Avatar
Default Re: 2001 CRV Rear Differential Leaking (elise)
Thanks for the exploded view, elise.
I finally got a mechanic to admit that sometimes the (liquid) seals, where the differential housing is joined, leaks - due to poor application when the components were assembled.
Its just unfornate this happened with such low mileage. Mechanic wants between 500.00 and 800.00 to correct the problem (dismantling, cleaning, resealing)! Seems pretty steep for this. I'll try to get the Honda people to repair it with a good faith warranty. If that doesn't work, I'll repair it myself.
Thanks, again.
Old Aug 17, 2006 | 02:15 PM
gamemaster000's Avatar
Bummer to have a failure with so low of miles. I guess it is 5 years old.. but still.
GL with your repair.
silentsay
Honda CR-V & Element
Jul 6, 2017 03:40 PM
beardly
Apr 18, 2014 04:48 PM
kennyb3030
Oct 27, 2008 11:46 AM
reno96teg
Jan 29, 2006 01:59 PM
