Suspension & Brakes Theory, alignment, spring rates....
Bleeding ABS.
Old Aug 15, 2006 | 11:15 AM
Miracle's Avatar
Default Bleeding ABS.
I have personally never bled an ABS system after opening it up. Anything different from Non-ABS to an ABS system?
Old Aug 16, 2006 | 07:29 AM
kaiba's Avatar
Default Re: Bleeding ABS. (Red_EM2)
I heard you need a special tool.
Old Aug 16, 2006 | 10:43 AM
Tyson's Avatar
Default Re: Bleeding ABS. (kaiba)
wheres the suspension tech?
Old Aug 16, 2006 | 12:11 PM
Miracle's Avatar
Default Re: Bleeding ABS. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">wheres the suspension tech?</TD></TR></TABLE>
Brakes are part of the suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">I heard you need a special tool. </TD></TR></TABLE>
Like something such as.......
Old Aug 16, 2006 | 12:46 PM
super_nguyen's Avatar
i thought it was the same for ABS and non ABS models where you start farthest away from where the brake reservoir is located and work your way, ie if its on the drivers side, start on rear passenger, then rear driver then passenger front then front driver side.
Old Aug 16, 2006 | 05:41 PM
Miracle's Avatar
Default Re: Bleeding ABS. (super_nguyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was the same for ABS and non ABS models where you start farthest away from where the brake reservoir is located and work your way</TD></TR></TABLE>
Yeah, that is how you do it on non abs. But what if you only have one person to do it. You pump the pedal too much, and start sucking air into the ABS motor and associated parts, I heard its a bitch to get out.
Surely someone knows what special needs to be done.
Old Aug 16, 2006 | 10:33 PM
chrisw85's Avatar
the abs circuit doesn't activate unless the abs computer senses it from the wheel sensors. So until then, the brakes act as normal, and you can bleed the brakes normally; ie bleeding the brakes normally would not 'suck air into the abs lines.'
FA All Day
Honda Civic (2006 - 2015)
14
Jun 11, 2008 07:07 PM
nsxxtreme
Mar 10, 2006 09:05 AM
Boosted00GSR
Jan 22, 2006 06:18 AM
SlammedDC2teg
Dec 3, 2005 03:14 PM
hndarcrb18c1
Oct 20, 2003 04:07 AM
