installing rear omnipower coilovers
Old Aug 15, 2006 | 11:03 AM
huntarrr's Avatar
Default installing rear omnipower coilovers
The rear stock oem shocks have the nut built in to the lower mount (where the bolt connects the shock to the lca). I'm trying to put on Omnipower coilovers and they didn't come with a nut... what did you guys do? Hardware store? Any special nut I should get? Whats the size and thread pitch?
Old Aug 15, 2006 | 11:25 AM
BLacK FirE's Avatar
Default Re: installing rear omnipower coilovers (vsm98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">The rear stock oem shocks have the nut built in to the lower mount (where the bolt connects the shock to the lca). I'm trying to put on Omnipower coilovers and they didn't come with a nut... what did you guys do? Hardware store? Any special nut I should get? Whats the size and thread pitch?</TD></TR></TABLE>
I'm pretty sure mine came with a nut.
Old Aug 15, 2006 | 11:40 AM
huntarrr's Avatar
Default Re: installing rear omnipower coilovers (BLacK FirE)
I bought them used.
But anyway, since i can't go to the hardware store until my suspension is intact, im just going to use one of the two bolts on top of the shock until i can get another.
Old Aug 17, 2006 | 08:08 AM
JdmTypeRdc2's Avatar
should come with a nut but just go to acura and get a new that made for it
Old Aug 17, 2006 | 09:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (JdmTypeRdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmTypeRdc2 &raquo;</TD></TR><TR><TD CLASS="quote">should come with a nut but just go to acura and get a new that made for it </TD></TR></TABLE>
You can't get one from Acura, the stock shocks have the nut welded onto the shock fork.
Just take your bolt to the store and find a nut that fits. They have little boards with studs and nuts on them to test different sizes so you can find the correct one.
Old Aug 17, 2006 | 09:47 AM
Lewie's Avatar
I'm here for the gangbang!
Just like everyone else has said, just run up to the hardware store and pick up a couple of nuts.
PapiCD5
Jun 2, 2018 11:56 AM
ChiLS
Aug 25, 2008 03:28 PM
KdiZzLe
Suspension & Brakes
Nov 29, 2006 10:03 PM
jbell
Jul 7, 2005 09:06 AM
hybridcrx
May 23, 2004 08:37 PM
