Help me please
Old Aug 15, 2006 | 08:14 AM
bwilly's Avatar
Default Help with idle searched and tried no luck
I have a 90 Si crx with a first gen b16a swap And I have searched and searched but can not find an answer. Like alot of honda's i have the retarded idle problem up down up down. i did a pressure test on the vaccum lines, no leak. I changed the IAC twice still didnt fix it and its throwing the code for iac still as well so i figure iac sensor is bad but When i unplug the sensor it changes and actually sounds better doing the idle bump in a range of 300 rpms when i plug it back in it goes back to the 2000 pm range so i figure the sensor is still good. next i check over the vacuum diagram and it looks way wrong from the 6 diagrams i saw and finally i went with the one that a majority of sites link to or say to use so i change the vacuum lines, reset the ecu, check coolant and once again it continues being gay. any help would be greatly appreciated
Modified by bwilly at 12:10 PM 8/15/2006
Modified by bwilly at 12:11 PM 8/15/2006
Old Aug 16, 2006 | 08:10 AM
bwilly's Avatar
Default Re: Help with idle searched and tried no luck (bwilly)
anyone???
Old Aug 16, 2006 | 10:12 AM
Mr. Giggles's Avatar
well what happened to me was my map sensor had a slice in one of my wires, so i just soldered it, and everything was fine...
When you drive the car, does it bog out or feel very drastic power loss when u hit the gas? If so, id check the map sensor.. because that's what was happening to me..
98bucket
Aug 20, 2013 08:46 PM
talley2191
Jan 31, 2006 07:13 PM
90AcuraIntegra04
Jan 16, 2006 11:46 AM
barry11j
Mar 9, 2005 07:11 AM
Mentat Ghola
Apr 27, 2004 03:48 PM
