Compensator arm trouble..
Old Aug 15, 2006 | 08:05 AM
Easy Eddy's Avatar
Default Compensator arm trouble..
Alright I'm trying to remove my rear compensator arms from my 97 hatch, but these suckers just dont want to come loose. On one side it looks like the metal collar inside the bushing is preventing the bolt from being removed and on the other it appears to be the same. Short of just cutting them off and getting a new set for $12 a piece does anyone have any advice or ideas? I sprayed the crap out of them w/ liquid wrench and let it set in but that didn't help a whole lot. Thanks.
Old Aug 15, 2006 | 08:16 AM
miahmouse's Avatar
Default Re: Compensator arm trouble.. (Easy Eddy)
just be careful with the end that goes into the frame... f-ing up the nut that's behind there is not good...
If you've tried heat, PB blaster, impact and breaker bar.... your only other option is cutting them off...
deschlong
Jun 24, 2012 11:27 AM
justinwebb
Apr 12, 2009 04:58 PM
dustin_crxsi
Suspension & Brakes
19
Apr 11, 2007 12:29 PM
Vinceg99
Apr 17, 2004 06:47 AM
TypeR892
Sep 17, 2001 02:43 PM
