tune up questions
Old Aug 15, 2006 | 06:29 AM
efking's Avatar
Default tune up questions
im going to buy a b16 swap and want to know where do i get the water pump and the timing belt. i mean wat make and model car.on a scale from 1-10 how easy is it to swap a 1st gen b16 in a 88 civic dx dpfi. thanks
Old Aug 15, 2006 | 10:24 AM
Mr.Smog's Avatar
Default Re: tune up questions (efking)
I heard you could use parts from a 90'-93' integra, people say those are interchangeable parts. I have the same swap but I have the Si model, you might need the dpfi wire harness. The guys that did my swap used my original harness but had to wire up the VTEC. You also need a VTEC ecu, a PR3 or PW0. I'm having problems getting parts for my car whenever something goes wrong. I had to get a new thermostat, asked for a 90'-93' Integra it was to small. I also had a problem with my CKP sensor which is built inside the dist., the 90'-93' did'nt fit so they had to rebuild my old one for $400.00. I'm having nothing but problems with this bitch, that's why I got it posted for sale. I recommend the second gen.
Old Aug 15, 2006 | 10:27 AM
bag's Avatar
bag
Default Re: tune up questions (Mr.Smog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking &raquo;</TD></TR><TR><TD CLASS="quote">im going to buy a b16 swap and want to know where do i get the water pump and the timing belt. i mean wat make and model car.on a scale from 1-10 how easy is it to swap a 1st gen b16 in a 88 civic dx dpfi. thanks</TD></TR></TABLE>
92 integra gsr..
depends,,it aint really that hard..convert to mpfi,add the 4 wires for vtec,take a big hammer and bang some ****,,get swap mounts and linkage,,etc..its not really that hard and theres write-ups every damn where on the web
Old Aug 15, 2006 | 10:54 AM
Mr.Smog's Avatar
Default Re: tune up questions (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">
92 integra gsr..
depends,,it aint really that hard..convert to mpfi,add the 4 wires for vtec,take a big hammer and bang some ****,,get swap mounts and linkage,,etc..its not really that hard and theres write-ups every damn where on the web</TD></TR></TABLE>
So bag, your saying the 92' Gsr parts are interchangeable with my first gen. B16a. Is that the B17(92' GSR)?
Old Aug 15, 2006 | 12:04 PM
Metal Typhoon's Avatar
one second.. here you go ...
B16a1 VTEC Parts List !!!
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol"
Old Aug 15, 2006 | 10:00 PM
91SiZ6's Avatar
Here's a thought, '94-'95 Del Sol VTEC or '99-'00 Si.
Old Aug 15, 2006 | 10:03 PM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Smog &raquo;</TD></TR><TR><TD CLASS="quote">
So bag, your saying the 92' Gsr parts are interchangeable with my first gen. B16a. Is that the B17(92' GSR)?</TD></TR></TABLE>
Yeah most of those parts will work from the B17A1 GSR..theres other motors that work like 94 delsol vtec but they always give you the wrong **** ,,giving you sohc vtec parts instead even if you tell them 100 times,,,so for something like that i like to order online a place like rockauto.com
Old Aug 15, 2006 | 10:06 PM
salman's Avatar
In esay words you can use any Dohc Vtec. water and timing belt
94DCTeg
Oct 30, 2020 10:46 PM
RacenCivic
Mar 15, 2006 07:49 PM
No
Apr 2, 2004 04:34 AM
88EF
Sep 14, 2002 02:45 PM
