CEL codes, what is actually the problem?
Old Aug 14, 2006 | 10:19 PM
remo's Avatar
Default CEL codes, what is actually the problem?
hi all, my moms 05 si is throwing a few codes out of the blue and im not sure what is actually the problem.
5: Manifold Absolute Pressure (MAP) Sensor Signal Lower Than Expected
Manifold Absolute Pressure (MAP) Sensor Signal Higher Than Expected
57:Camshaft Position (CMP) Sensor No Signal
Variable Valve Timing Control (VTC) Phase Gap
Camshaft Position (CMP) Sensor Intermittent Interruption
41:Air Fuel Ratio (A/F) Sensor (Sensor 1) No Activity Detected
Air Fuel Ratio (A/F) Sensor (Sensor 1) Signal Stuck Lean
Air Fuel Ratio (A/F) Sensor (Sensor 1) Heater Circuit Malfunction
Air Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction
i checked a little DIY guide for diagnostics for an RSX and this is what i came up with. not really sure how all this could be wrong, as the car seems to be running fine, however not driving it now until the problem is figured out
any help would be awesome, and yes the car is still under warranty
Old Aug 14, 2006 | 10:21 PM
Miracle's Avatar
Default Re: CEL codes, what is actually the problem? (remo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remo &raquo;</TD></TR><TR><TD CLASS="quote">and yes the car is still under warranty</TD></TR></TABLE>
Thats your solution..... Take it to the dealership and make them figure it out. Get what you paid for... Just my $.02
And you may want to post this in the EP3 Si/DC3 RSX-s forums, you may get alot more help there.
Click me click me!!!
Old Aug 14, 2006 | 10:40 PM
remo's Avatar
ok, i didnt realize this is the wrong place for this.
Old Aug 14, 2006 | 10:42 PM
Miracle's Avatar
Its all good, not like it hasnt happened before and wont happen again.......
Old Aug 14, 2006 | 10:47 PM
toyomatt84's Avatar
Sanji
Default Re: CEL codes, what is actually the problem? (Red_EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Its all good, not like it hasnt happened before and wont happen again.......</TD></TR></TABLE>
TRUTH.
Old Aug 15, 2006 | 11:51 AM
remo's Avatar
Default Re: CEL codes, what is actually the problem? (toyomatt84)
took it to the dealer and there was nothing wrong with it i guess. sorry for the repost
CalmPalmTree
May 1, 2015 05:03 AM
91ef8sir
20
Jan 29, 2013 11:24 AM
Layziejoe775
Oct 14, 2005 08:47 PM
jpangeles
Sep 12, 2004 05:23 PM
