ZC Oil Pump
Im having a little problem....after changing my oil, the oil light started to flicker(oil level is fine), it wasnt on all the time, it was just flickering. I was thinking this might be the oil pump starting to go, but i cant find which oil pump to use for the ZC anywhere, does anyone know? Also, are there any ideas on what else might be causing the light to flicker, maybe a wire i jostled under there thats grounding out now? Thanks for the help.
Mike
Mike
a good rule of thumb for the zc is that the head is basically the same as the 88-89 teg and the bottom end is similar to the 88-91 civic/crx...
edit: boobies are good
[Modified by marked001, 1:55 PM 4/25/2002]
Hmm, so you guys are thinking that a stock replacement for my old engine(d15) would work...dustin, does the ZC oil pump you have seem similair to one from a 4g, oh and how much would it cost, shipped...thanks
Mike
edit: yes, boobies are good, i agree
[Modified by Phatman91624, 8:36 PM 4/25/2002]
Mike
