H22 OBD 1
I think ur good man, as long as it's obd1 it should have the same sensors, and the ignitor and the coil should work just fine too, in fact i've used the ignitor and coil from an obd2 with diff numbers on them and they've worked just fine in my h22 obd1 dizzy. But i'm pretty sure the sensors should be the same, if not, u'll get a cel pretty fast, but I'm almosty 100% positive they do, although I haven't swapped my entire dizzy with a b16's so i'm not 100% sure though. Bump.
all the obd1 wiring is the same. i cross checked mine (93 teg obd1) between my ecu plugs and the h22 ones and there all the same. cept for some lil stuff that dont matter.. and yea all the sensors are the same. are the plugs are the same
dacosta
Dec 9, 2004 09:38 PM
