passanger door drops when i open it
Old Aug 14, 2006 | 07:16 PM
ac_attak's Avatar
Default passanger door drops when i open it
Hey, the passanger door on my car doesnt fit flush and drops noticeably when i open it. Is there any adjustment i can do to make it fit more flush? I am guessing the door hinges may be bent where the door drops and its also hard to open.
Old Aug 14, 2006 | 07:21 PM
jennsGSR's Avatar
Default Re: passanger door drops when i open it (ac_attak)
check the hinges, and maybe new bolts.
Old Aug 14, 2006 | 07:35 PM
-Todd-'s Avatar
Default Re: passanger door drops when i open it (jennsGSR)
http://www.we-todd-did-racing....5NTQx
Try just adjusting that first... if that doesnt do the trick take the fender off and loosen the bolts that hold the door on, then adjust it till its flush. It does take some time to get it just right tho.
Old Aug 14, 2006 | 07:38 PM
PrinceAli132's Avatar
Default Re: passanger door drops when i open it (-Todd-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Todd- &raquo;</TD></TR><TR><TD CLASS="quote">http://www.we-todd-did-racing....5NTQx
Try just adjusting that first... if that doesnt do the trick take the fender off and loosen the bolts that hold the door on, then adjust it till its flush. It does take some time to get it just right tho. </TD></TR></TABLE>
I don't think adjusting that will help with his problem because the door sags when open so it has to do something with the two hinges near the fender.
Ali
Old Aug 14, 2006 | 07:41 PM
-Todd-'s Avatar
Default Re: passanger door drops when i open it (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think adjusting that will help with his problem because the door sags when open so it has to do something with the two hinges near the fender.
Ali</TD></TR></TABLE>
Doesnt hurt to start there Prince.
Old Aug 14, 2006 | 07:45 PM
Doesnt hurt to start there Prince. </TD></TR></TABLE>
Touche
Ali
Old Aug 14, 2006 | 07:47 PM
ac_attak's Avatar
Ok i'll try that out tomorrow morning.
Oh and just some extra info, its the rear of the door where it doesnt fit flush. Its probably about 1/4" from being closed all the way.
Old Aug 14, 2006 | 07:54 PM
trick_db's Avatar
try checking inside your door, probably got like major sack of weed in it
Old Aug 14, 2006 | 08:07 PM
POE's Avatar
POE
did your car ever get in a wreck that You know of?!?!, did it ever fall off a jack? or was not proberley supported at one time?
Old Aug 14, 2006 | 08:18 PM
ac_attak's Avatar
Default Re: (POE)
Yeah the car was in an accident, i dont know the details of it but there is no frame damage. I am sure thats why the door is the way it is. I am going to take it to a body shop and have them take a look at it if i can fix it up myself.
Keep the suggestions coming..
Old Aug 14, 2006 | 08:27 PM
POE's Avatar
POE
thats your problem, does the door close easily? do u have a picture of the door and what way it sits?
and if its liveable i would just keep on truckin, if not go to a body shop, but gonna cost a lot of MULA
Old Aug 14, 2006 | 09:05 PM
natedawg500's Avatar
had the same problem with my drivers side door. nothing would fix it. so i ordered 2 new hinges from acura. @ 35 bux a piece. fixed it. but still haven't got the adjustment just right. need to pull the fender but i'm too lazy.
Old Aug 14, 2006 | 09:06 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">Oh and just some extra info, its the rear of the door where it doesnt fit flush. Its probably about 1/4" from being closed all the way.</TD></TR></TABLE>
If the Flush part is it being that it doesn't close all the way, adjust that piece Todd mentioned,
Loosen it up, then move it inwards, and then retighten.
lax1089
Feb 3, 2007 05:50 PM
itellyawhat
11
Feb 19, 2005 01:07 PM
acourt
Nov 27, 2004 05:38 PM
CB_ejcoupe
Jan 26, 2004 02:35 PM
andrewasf77
Feb 9, 2003 08:41 PM
