transmission fluid leak
my car leaked all the tranny fluid im assuming from right in front of the radaitor i just put it. The trans won't go in any gear it just spins like its in neuteral so how much fluid should i be putting back in? And whats the best way to do this?
the hondas will use 3 quarts of Honda Z-1 ATF
on your accord you put the trans fluid in the hole where the dipstick is.
Check the fittings that thread into the trans cooler part of the radiator, they might have come loose during shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">the hondas will use 3 quarts of Honda Z-1 ATF
Check the fittings that thread into the trans cooler part of the radiator, they might have come loose during shipping.</TD></TR></TABLE>
yeah i know, i figured that one out haha. are you sure its only 3 quarts? I think all of it came out.. since it was running and moving when the leak happened, i think it might be completely empty, even the torque converter
turbotaylor
Jan 29, 2007 06:21 PM
