Bad Piston Rings
Old Aug 14, 2006 | 06:33 PM
2fknlo's Avatar
Default Bad Piston Rings
Hi peeps i've got low compression and did a wet test to confirm rings.
Now with the CTR pistons do i have to use genuine Honda rings? or can i use any aftermarket type.
Thanks
Old Aug 14, 2006 | 07:53 PM
EG2Driver's Avatar
Default Re: Bad Piston Rings (2fknlo)
i would use OEM honda parts for internals like that...they just make them right to begin with. OEM FTW
Old Aug 15, 2006 | 06:36 AM
ITRnorway's Avatar
is the type R pistons forged?
but would you choose the CTR pistons if the the CP or Wiseco was the same price?
lighter is better
but on topic: seems smarts to use oem rings on oem pistons
Old Aug 15, 2006 | 01:04 PM
unknown0001's Avatar
Default Re: Bad Piston Rings (DeadEnd9009)
You can use hastings rings or any other aftermarket piston ring that has a good rating on it.
Hastings are in my b18b and love them...I also installed them in my friends cars and holding up and sealing great.
Get whatever you can buy both will do the job equally the same
Old Aug 15, 2006 | 04:28 PM
slo blue's Avatar
Default Re: Bad Piston Rings (Mr.RHTuner)
i have put 3 different motors together using different ring everytime. they all seal the the same but the honda rings seem to last longer than the other 2 aftermarket type.
Old Aug 15, 2006 | 04:44 PM
Ed 341's Avatar
Default Re: Bad Piston Rings (slo blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo blue &raquo;</TD></TR><TR><TD CLASS="quote">i have put 3 different motors together using different ring everytime. they all seal the the same but the honda rings seem to last longer than the other 2 aftermarket type. </TD></TR></TABLE>
Sorry to thread-jack but when installing new rings it is neccessary to hone the cylinder bores, correct? Is this something a machine shop has to do or is it something you can DIY?
Old Aug 15, 2006 | 07:13 PM
h8ted ek's Avatar
Default Re: Bad Piston Rings (Ed 341)
I believe honda has some sort fo a guidline that you should hone the cylinder by a hair length depending on the conditino of the cylinder wall. Ive had the same question and asked a tech at honda If the cylinder walls are scratched up in the walls then you should have it hone wiht a machine. But if its not scratched up then you can DIY by hand. im not sure what he uses but its just polishing the cylinder wall by hand. This is from i was told so, dont take my word for it.
anyone else want to chime in. I myself will need a rebuild soon summer/spring of next year i have a bad piston ring and headgasket, thats still drivalbe but im def doing headgasket in a few weeks. Im not too sure what kind of pistons i wanna use def a high compression one and defintly forged dont know how big of a bore i wanna go. I just dont want to do a rebuild again till next 120,000 miles
Modified by H8ted Ek at 8:26 PM 8/15/2006
Old Aug 15, 2006 | 07:24 PM
slo blue's Avatar
Default Re: Bad Piston Rings (H8ted Ek)
it is ideal when installing new rings to have a fresh hone on the cylinder wall. if there are no deep scratches then goto napa or autoparts store and buy a ball hone for the size you need. make one pass up and down to freshen up the factory cross hatches.
if there are deep scratches then the block may need to be bored then honed.
Old Aug 15, 2006 | 11:05 PM
2fknlo's Avatar
Hi the block has only done 3000kms.
Not sure why i the piston rings went bad. Im guessing not high enough octane, no tuning(standard computer) and didn't break in motor properly.
Im only asking since i got a mate that sell auto parts and can get me a deal than paying a premium for genuine ones.
Do i need to rehone the block also?
Thanks
Old Aug 16, 2006 | 03:58 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fknlo &raquo;</TD></TR><TR><TD CLASS="quote">Im only asking since i got a mate that sell auto parts and can get me a deal than paying a premium for genuine ones. </TD></TR></TABLE>
I'd say spring for genuine Honda parts for this rebuild
Old Aug 16, 2006 | 05:02 AM
200cs's Avatar
I would rehone as you may have glazed down the cyl walls from an over rich condition-the new rings may not seat either....
I use one of the universal stone type hones and it works great if you keep it lubricated with wd40 while you are cutting. If you are hesitant to do it yourself take the block to a machine shop and they will do it for you for a nominal fee.
You need to get your tune right or you will be here again. It takes some friction for the rings to seat in and if you are overly rich then they may not....
Blake St.romain
Aug 26, 2018 08:34 PM
eg6nike
May 17, 2010 05:46 PM
quik1
Jun 9, 2004 07:48 PM
hybridEj6
Apr 15, 2003 07:50 PM
KENetics1
Apr 7, 2003 11:43 AM
