Gasket question
Old Apr 25, 2002 | 09:25 AM
SamC's Avatar
Default Gasket question
Do I need a gasket/o-ring between the carsound cat and stock R exhaust? I purchased an OEM O-ring gasket from Acura but it was too small, so currently I just install the cat to the exhaust without a gasket. If I need one, what size do I need to get? where can I get one? what's the part number? Thanks
Old Apr 25, 2002 | 09:29 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Gasket question (SamC)
You've got the 2.5 inch carsound cat right? Get a standard 2.5 inch exhaust gasket or buy some material and cut one yourself. If you're lazy or don't know where to start I'm sure you can get a local muffler shop to put one in for you for about 10 bucks.
Old Apr 25, 2002 | 09:40 AM
IntegraT's Avatar
I would say do a search but...It DOSN'T WORK anymore.
https://honda-tech.com/zerothread?id=167629
https://honda-tech.com/zerothread?id=167178
SamC's Avatar
Default Re: Gasket question (newt2)
Thanks...I was under the impression that I need one similar to stock (O-ring)...but I'll got get a 2.5 gasket later..thanks
Old Apr 25, 2002 | 09:53 AM
SamC's Avatar
Just curious...
Connector donut goes at the end of the header and o-ring/gasket goes between cat and exhaust...right? Do I need to replace both every time I take them off?
Old Apr 25, 2002 | 09:57 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I wouln't think you would need to replace the gasket, but the donut on my car turned to goo after a few months so I'm sure if I take it off I'll need a new one.
Old Apr 25, 2002 | 10:09 AM
JPP's Avatar
JPP
Yes the donut goes at the end of the header. And you can use a gasket between the catalytic converter and the B pipe of the exhaust but at worst you can use some high temp. caulking to seal the joint.
And no you don't need to change them each time you take the exhaust system apart. If the gaskets are good you can reuse them
Just as an information, you should not use the term "o" ring for any gasket on the exhaust system.
dod
Jun 30, 2006 09:19 AM
Yellow Submarine
Jan 5, 2005 06:28 AM
bsixteen
May 23, 2004 02:17 PM
jdmspoonitr
Sep 22, 2002 03:31 PM
