what do you guys think?
Old Aug 14, 2006 | 06:01 PM
jennsGSR's Avatar
Default what do you guys think?
ok, so since i spun a bearing, i am changing out the crank and rods, all eagle, and im putting a set of skunk 2 cams in it.. what difference will i feel? and what do you guys think about it?
Old Aug 14, 2006 | 06:19 PM
Leo C's Avatar
Night Owl
Default Re: what do you guys think? (skinnyshugg)
Is this an LS? It might be cheaper in the end to pick up a new shortblock, even a b20. Then go from there.
Old Aug 14, 2006 | 06:20 PM
Tornadom's Avatar
I think that your bottom end will be ready for a good set of forged pistons. If you are already in there, you might as well do it. As for the cams, without knowing which profile, which motor/head, and other modifications it is hard to say. I think that you can expect a strong motor, that has the potential to withstand good power.
Old Aug 14, 2006 | 06:41 PM
PrinceAli132's Avatar
Default Re: what do you guys think? (jennsGSR)
I agree with Tornadom, if you can afford it i would up the compression a bit and get some nice pistons as well.
Are you going to be running stock valvetrain and exactly what skunk2 cams are you going to be running.
But it seems like your on the right track. Goodluck with the build.
Ali
Old Aug 14, 2006 | 06:50 PM
95jdmdc4's Avatar
if you wanna go for it, bore it over to a 2.0 or get the b20 bottom end, you will love the extra torque. I swapped my ls after it was hassling with me and put in a jdm-spec b20, and the torque difference is very considerable. Good luck with whatever you do man.
Old Aug 14, 2006 | 07:00 PM
Im not sure about this, but don't the S2S2 cams need a bit higher compression to get more out of them?
Ali
Old Aug 15, 2006 | 04:11 AM
George Knighton's Avatar
H-T Order of Merit
I do not want to be in this thread, but people keep reporting it.
Please stay on topic.
Old Aug 15, 2006 | 10:35 AM
bboysake's Avatar
how is this off topic? Well oops I guess I just did : )
Old Aug 15, 2006 | 01:27 PM
AkMikeO's Avatar
DO IT!
Honda_Cribb_GS-R
21
Nov 27, 2009 10:00 AM
B20 Civic
Jan 18, 2008 06:09 AM
EK FLY
Feb 7, 2007 10:43 PM
awdlaunchmonster
Jul 8, 2004 12:36 AM
Propulsion
Dec 9, 2003 10:25 PM
