b18c bottem end bearing replacement??
Old Aug 14, 2006 | 05:48 PM
djtrini's Avatar
Default b18c bottem end bearing replacement??
Hey looking for some insight here, ok disassembled my b18c block which has stock internals. I got the std ACL bearing kit. Which consists of rod, mains and thrust washers. Also went ahead and picked up some ARP rod bolts and brand new piston rings.
Now I had the intenals removed in order, and my father being the own way guy he is moved around the box w/ parts so the pistons/rods are no longer in the order I removed them in.
So my question is, if anyone can help.
is it necessary to install the pistons w/ rods back in the same order I removed them? Since im using new std size bearings?
Any help is greatly appreciated.
TravisBiggie
Apr 10, 2013 08:21 AM
CRX91SE
Feb 20, 2012 02:32 AM
ulemu
Nov 14, 2005 09:34 AM
h22a193
Nov 14, 2004 10:16 AM
jdmhatch94
May 20, 2003 08:02 PM
