Is it possible to repair radiator leak?....how?
Some how a tiny hole got punctured into my radiator where the metal fins are. I can see radiator fluid squirt out a little bit when i press down on the radiator hose. Is there a reliable way of fixing this problem instead of buying a whole new one? Im strapped for cash right now, and the hole looks so small..........
Stop Leak.
Actually I wouldn't use that stuff. It just doesn't seem like a good idea to put of bottle full of metal shavings into your coolin system. At least on an ITR anyway...
try pepper? I have herd that if you put pepper in there it will stop the leak and you will be good 2 go ? but get more info on this B4 you try -k-
good luck
good luck
Stop leak does work, I'ves used in on cheap cars before and it stops small leaks like a champ. If you do decide to use it, fluch your coolant syatem after you seal the leak just to get the particulate material out of there.
It's meant to be a temp fix, but ou should be fine for a month or two until you can get one of those nice racing radiators.
O16581724 5 2 5
Welding / Fabrication
23
Dec 7, 2005 09:01 PM
Works in the cartoons!
