FS: manifold, T4/T67, sleeved engine, Autronic etc
Located in Louisville KY, you can reach me at 502-639-5235 or bill@autolabonline.com if you have any questions. Prices do not include s&h and are best offer.
Built/Sleeved B16 engine, 10mm deck plate and LS internals makes it now a 2.0L engine. Has 0 miles on it. Head just received radius valve job, surfacing, new seals, etc. JE/Crower internals, ERL main girdle, Cometic gasket, CTR cams, Supertech valvetrain, Edelbrock int manifold, Moroso pan, all new OEM parts - pumps, belts, overhaul gasket kit. $5300 for longblock or split the head & block and buy block for $3500 and the head/cams/int manifold/valvetrain for $1800
T4 turbo manifold for B series with 4" stainless downpipe, brand new never used. $1200 for both
Tial 38mm gate, red. 14psi spring, has race valve. Used. $150
Garrett 67mm turbo, T4 turbine .70a/r with vband discharge. brand new inthe bag from phoenix turbo.com. $950
huge front mount kit with alum piping and Tial BOV (red). $650
Moroso catch can with additional bung welded to it for dual entry. -10AN black lines with all 90* fittings for valve cover/crankcase breather kit. Includes powdercoated Honda B16 valve cover with 2 -10AN fittings welded. $200 and your stock B series valve cover.
BBK 70mm throttle body with Honda intake manifold adaptor plate. Brand new in the box never used. $190 for both.
Lenso 13" wheels with M&H 26" slicks, fits 4x100. Slicks have 4 passes, $550.
B16 cable trans, just overhauled with all new parts, needs nothing, so clean you could eat off of it. $600
Hasport mount kit/linkage - used 2000 miles. exc cond. $375
Autronic SM4 engine mgmt system and Autronic CDI, both brand new in box with manuals, sensors, harnesses, etc. $2100 for ecu and $950 for the CDI.
CircuitWorx Honda axles with spool and intermediate shaft. Also comes with outer hubs with extended studs. Brand new never used. $2000, almost $1000 off retail. good for 850 wheel and 28" slicks.
14ft single axle trailer, ok shape, pulls straight. needs a little TLC $200
gotboosthatch
Feb 24, 2008 02:53 PM
popnvtec
Jan 9, 2006 09:44 PM
