***Parting out drag CRX - turbo, Autronic, slicks, built engine, axles etc***
Old Aug 14, 2006 | 03:51 PM
AutoLab's Avatar
Default ***Parting out drag CRX - turbo, Autronic, slicks, built engine, axles etc***
Located in Louisville KY. You can reach me at 502-639-5235 if you have any questions. My email is bill@autolabonline.com
90 CRX rolling chassis, this is my black car. Has 6pt cage, painted black, all interior except rear section, good Si seats, no stock wiring but we made our own relay panel so headlights, turns, tails etc work off stock stalks. Has KYB/Skunk2 drag coilover suspension setup with Avid front traction bars. Has custom fuel cell, Aeromotive A1000 pump, regulator, filter and custom -12AN lines. Add your drivetrain and engine mgmt and you have a 100% car. Car has clean title and is in good shape. $1500 firm.
Built/Sleeved B16 engine, 10mm deck plate and LS internals makes it now a 2.0L engine. Has 0 miles on it. Head just received radius valve job, surfacing, new seals, etc. JE/Crower internals, ERL main girdle, Cometic gasket, CTR cams, Supertech valvetrain, Edelbrock int manifold, Moroso pan, all new OEM parts - pumps, belts, overhaul gasket kit. $5300 for longblock or split the head & block and buy block for $3500 and the head/cams/int manifold/valvetrain for $1800
T4 turbo manifold for B series with 4" stainless downpipe, brand new never used. $1200 for both
Tial 38mm gate, red. 14psi spring, has race valve. Used. $150
Garrett 67mm turbo, T4 turbine .70a/r with vband discharge. brand new inthe bag from phoenix turbo.com. $950
huge front mount kit with alum piping and Tial BOV (red). $650
Moroso catch can with additional bung welded to it for dual entry. -10AN black lines with all 90* fittings for valve cover/crankcase breather kit. Includes powdercoated Honda B16 valve cover with 2 -10AN fittings welded. $200 and your stock B series valve cover.
BBK 70mm throttle body with Honda intake manifold adaptor plate. Brand new in the box never used. $190 for both.
Lenso 13" wheels with M&H 26" slicks, fits 4x100. Slicks have 4 passes, $550.
B16 cable trans, just overhauled with all new parts, needs nothing, so clean you could eat off of it. $600
Hasport mount kit/linkage - used 2000 miles. exc cond. $375
Autronic SM4 engine mgmt system and Autronic CDI, both brand new in box with manuals, sensors, harnesses, etc. $2100 for ecu and $950 for the CDI.
CircuitWorx Honda axles with spool and intermediate shaft. Also comes with outer hubs with extended studs. Brand new never used. $2000, almost $1000 off retail. good for 850 wheel and 28" slicks.
14ft single axle trailer, ok shape, pulls straight. needs a little TLC $200
Old Aug 22, 2006 | 02:33 PM
AutoLab's Avatar
Default Re: ***Parting out drag CRX - turbo, Autronic, slicks, built engine, axles etc*** (AutoLab)
emails returned, engine possibly sold.
Old Sep 3, 2006 | 06:14 PM
AutoLab's Avatar
autronic and cdi sold
mtflyboy25
Jul 13, 2013 07:01 PM
jspeccrx91
May 22, 2009 06:55 AM
HatchSi
Apr 29, 2007 10:08 PM
AutoLab
Jan 1, 2006 07:45 PM
9SECQTR
Jan 30, 2004 04:08 PM
