need some help- Shifter Shaft seal installation??
Old Aug 14, 2006 | 02:31 PM
vestalfootball72
Guest
Posts: n/a
Default need some help- Shifter Shaft seal installation??
To install the shiftet shaft seal do you have to remove the tranny and the guts to get to it, or can you just pull the linkage and put it in- I pulled the linkage and put it in but it didnt really fit correct?
Old Aug 14, 2006 | 02:32 PM
jameskersten1's Avatar
Default Re: need some help- Shifter Shaft seal installation?? (vestalfootball72)
B series should be external so you shouldnt have to remove the trans
Old Aug 14, 2006 | 02:56 PM
vestalfootball72
Guest
Posts: n/a
Default Re: need some help- Shifter Shaft seal installation?? (jameskersten1)
its external, but i went to a tech and he said hed look into it because sometimes on cars you have to pull the tranny apart- I searched tho and found out you dont -
Old Aug 17, 2006 | 11:23 AM
vestalfootball72
Guest
Posts: n/a
Alright another tech told me i had to split the case- any input>?
dopehouse
Transmission & Drivetrain
Oct 26, 2011 09:51 PM
odidipissuoff
Mar 16, 2010 06:45 PM
turbo2kteggy
Dec 29, 2007 11:21 AM
anahaevia8
Jun 21, 2007 06:07 PM
B18CJDM ITR
May 31, 2004 02:03 PM
