I need advice on my next build- D-motor
I want to drop a D16 motor in my EK hatch. My goals are mid 13s or lower. I really dont know anything about F.I, what is needed for a good setup. I have that D16 blocks have really strong sleeves and thicker rods than Bmotors, true?
D16 are pretty cheap, 300-500 for a full swap. can someone point in the right direction of what i should be reseaching and etc.. my plan was buy a block and replace things like the water pump, gaskets etc.
I wanted to do all the "pre-work" first. like get the gauges, boost control , etc. bigger exhaust, whats a stuff is needed and wat is best?
-is d15 or d16 block better for turbo?
-whats the big differcne between all these diff mainfolds, ram log etc?
- whats a good CR for a FI motor, 10.3?
Z6 /Z6 Block - 9.13:1
Z6 /y8 Block - 9.21:1
Z6 /A6 Block - 9.95:1
Z6 / D15 - 10.10:1
Z6 / Y7 - 9.62:1
Y8 / Z6 - 9.45:1
Y8 / Y8 - 9.61:1
Y8 / A6 - 10.33:1
Y8 / D15 - 10.52:1
Y8 / Y7 - 9.96:1
try posting in the FI forum. and d series rods are like tothpicks, only good up to 200 give or take. you want a lower comp for turbo, like 9:1, z6 seems to be the fav around here for boosting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">If you want those numbers you'll have to go with a turbo. Nothing else will do that in a D-series w/o dropping tons and tons and tons of money on it.</TD></TR></TABLE>
your wrong, people are putting down those numbers, N/A, for the same price as a b swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">
your wrong, people are putting down those numbers, N/A, for the same price as a b swap.</TD></TR></TABLE>
A swap to make those numbers would be cheaper & easier than fixing up a D-series to do that.
Most of the information you're looking for is already available in other threads. If you can't find exactly what you're looking for, try researching a little, narrowing down your questions, and asking in the forced induction section, or any section that directly pertains to your question. Right now it seems like you have a lot of info to take in and digest. Fast Honda's are a very broad subject. Good luck with the build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">whatsa better head y6 or y8</TD></TR></TABLE>
y6? do you mean z6? If so, the z6 is better in the sense that it flows more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">whats the differnty between y7 and y8?</TD></TR></TABLE>
the main difference is that y7 is non-vtec and y8 is vtec.
bnmm
Nov 18, 2013 06:17 AM
EJ8-y8
Apr 9, 2006 03:50 PM
