tow a 700lb trailer with a del sol?
Old Aug 14, 2006 | 12:48 PM
sportbike954's Avatar
Default tow a 700lb trailer with a del sol?
i probably won't do it, but i was curious what you guys thought about a 96 del sol dohc vtec hauling a 700lb load (300lb trailer, 400lb sportbike). i think the owner's manual says the warranty will be void if the car is used to haul a trailer, not sure though.
ironically, i noticed they make trailer hitches for a del sol, so that got me curious.
Old Aug 14, 2006 | 12:49 PM
sicones's Avatar
Default Re: tow a 700lb trailer with a del sol? (sportbike954)
you have a warranty on a 96 delsol??
Old Aug 14, 2006 | 12:56 PM
Default Re: tow a 700lb trailer with a del sol? (sicones)
the point is if they're going to void a warranty over some thing, then there may be a justified reason for not doing the thing in question. maybe not. so i'm asking.
Old Aug 14, 2006 | 01:04 PM
Ghetto Civic HX's Avatar
I love to drive
I think sicones point is that it's unlikely you still have a manufacture's warranty on a del sol. Just about any damage done to your car wouldn't be covered.
Old Aug 14, 2006 | 01:13 PM
Miracle's Avatar
Default Re: tow a 700lb trailer with a del sol? (Ghetto Civic HX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghetto Civic HX &raquo;</TD></TR><TR><TD CLASS="quote">I think sicones point is that it's unlikely you still have a manufacture's warranty on a del sol. Just about any damage done to your car wouldn't be covered.
I think the OP knows this. He is just saying that since Honda WOULD HAVE voided thee warranty by towing anything, then it wouldnt be advisable to tow something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportbike954 &raquo;</TD></TR><TR><TD CLASS="quote">the point is if they're going to void a warranty over some thing, then<U> there may be a justified reason for not doing the thing in question</U>. maybe not. so i'm asking.</TD></TR></TABLE>
Old Aug 14, 2006 | 01:41 PM
WrongWD's Avatar
i dont know about warranty, but i've seen crx's around town towing small 15' boats. I'm considering buying a tow hitch for my del sol so that i can fabricate a tire tail for some r compounds
Old Aug 14, 2006 | 03:34 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 9:28 AM 11/16/2006
Old Aug 15, 2006 | 10:32 AM
Default Re: tow a 700lb trailer with a del sol? (schlit)
yeah, i may end up selling it and getting a larger car. maybe a mini-van.
anyone in the dc/va/md area interested in a 1996 del sol dohc vtec?
http://washingtondc.craigslist....html
Old Aug 15, 2006 | 10:45 AM
dohcVTECeg2's Avatar
dont get rid of something so rare......
Old Aug 15, 2006 | 11:50 AM
fventura03's Avatar
DEL SOL, rare?
Old Aug 15, 2006 | 12:38 PM
mike1114's Avatar
Default Re: (fventura03)
My VX had a hitch on it when I bought it. I can tell they definitely used it cause the Input shaft bearing on the tranny MADE SO MUCH DAMN NOISE it was rediculous.
The car still shifted like butter and still does today (this is a year ago I got the car) it just makes that annoying chatter sound when you don't have the clutch depressed.
Old Aug 15, 2006 | 12:44 PM
solerizr's Avatar
Yeah a black 96 DOHC VTEC Sol is very rare, not to mention finding one that isnt totally thrashed.
Old Aug 15, 2006 | 02:37 PM
BiffStroganoffsky's Avatar
Wrong coast, otherwise I would be interested.
Old Dec 7, 2010 | 03:53 PM
Tugg Speedman's Avatar
I've been doing this for years. It cracks me up when people poo poo it. I bought my 1994 Honda Del Sol S and tow hitch in May of 2007. I haul 5x8 trailers from Uhaul that weight over 1,000 lbs. plus a few hundred pounds worth of furniture. On occasion I will haul a 5x10, 700 lb trailer with a canoe in it. On the weekends, I put a kegerator on a cargo hitch and haul that to the beach. As far as I'm concerned, Honda Del Sol's are the tug boats of the road.
Old Dec 7, 2010 | 04:07 PM
94EG8's Avatar
Seagull Management
The issue is never having enough power to tow, its always the car having enough weight over the wheels to stop and not just get pushed around.
Old Dec 7, 2010 | 04:15 PM
Big Rigs weigh less than 20,000 lbs and haul more than 40,000 lbs. They do have a long wheel base and good brakes, but it gives perspective. A Del Sol should have no problem braking with 2,000 lbs towing behind.
Old Dec 7, 2010 | 04:18 PM
Old Dec 7, 2010 | 04:43 PM
AutoXer's Avatar
Do they even make a hitch for the Sol? Is it the same frame as a Civic? If so, you'll have no problem pulling 700lbs. I wouldn't go much over that (that's just me) but you should be fine. I've been towing with my EX for about 7 years now. I don't have any pics of it with towing anything (since it's so old now, no photo shoots anymore) but here it is with the hitch in action:
Rated for 1000lbs tow, 200lb tongue wt. The tires and rack were probably over the tongue weight (azenis on steelies are heavy) and have towed 500lbs without noticing it much more than a carload of people.
Old Dec 7, 2010 | 04:56 PM
94EG8's Avatar
Seagull Management
You're forgetting that a transport is designed to tow all the time, the front of the trailer sits directly over top of the 2 drive axles. You're also forgetting that the trailer has brakes. Small single axle trailers don't normally have brakes.
Old Dec 7, 2010 | 05:29 PM
faztec1's Avatar
I just wouldn't tow anything in a Sol if I was you.
Old Dec 7, 2010 | 06:42 PM
AutoXer's Avatar
But we're not talking about a truck or transport. A decent small trailer would be balanced on the tongue of the hitch, and wouldn't load it at all. Given that, 700 lbs is within the load capacity of the car and shouldn't have a problem pulling it.
Old Dec 7, 2010 | 07:30 PM
94EG8's Avatar
Seagull Management
You're missing the point, the trailer has no brakes, it doesn't take much to push a small car all over the place. Although 700lbs is definately well in the range of what a Civic/Del Sol can safely tow.
Old Dec 7, 2010 | 07:54 PM
AutoXer's Avatar
What point am I missing; your second sentence agrees with what I said. If you stay within the ratings, you'll be fine... I've done it myself many times.
Old Dec 7, 2010 | 08:10 PM
98civdx's Avatar
Master Detailer
I think as long as you take it easy, and try to stay away from any large hills you should be ok.
My freind used to tow his race bike to the track with his civic all the time with only one problem. He couldnt make it up the last hill if he got caught at the light. He would need to hit the hill at 35-40mph.
Old Dec 7, 2010 | 08:22 PM
DCRB's Avatar
you also have to be smart about loading the weight and stopping, give yourself extra stopping distance whenever possible, and put 60% of the weight in front of the trailers axle so the trailer doesn't fishtail like crazy... atleast that is what i learned when i worked at uhaul two years ago
