Eagle talon turbo?
Old Aug 14, 2006 | 12:24 PM
square_1's Avatar
Default Eagle talon turbo?
Are turbos pretty interchangable? My friend has a 92 Eagle Talon, if he sold me his turbo and intercooler would that be usable in a 89 Civic Hatch?
Old Aug 14, 2006 | 12:27 PM
Loserkidwac's Avatar
Default Re: Eagle talon turbo? (square_1)
Yea you can use it but you need to make sure the manifold you get is made for a DSM turbo...
Old Aug 14, 2006 | 12:29 PM
ludesrv's Avatar
I beleive that's a 14B turbo? Correct? If so, they make adapter plates for them. Look into HF manifold adapter plates, there is a wide range out there.
Old Aug 14, 2006 | 12:32 PM
Default Re: (ludesrv)
yea i believe the 1st gens had 14b's, they are small turbos and you can usually find them for less than $100shipped in good condition and the side mount intercoolers go for about $30-$50 shipped i think...and the hf plus adapter plate is great for a cheap turbo set up
Old Aug 14, 2006 | 03:53 PM
mullenite's Avatar
make sure it is a 14b and not a 13g. if it is a 13g it isn't worth the time.
Old Aug 14, 2006 | 04:07 PM
91crxturbo's Avatar
Default Re: Eagle talon turbo? (mullenite)
13g = 3000gt/GTO/Stealth.....the 14b out of a talon/eclipse isnt bad...kinda small but good for a budget build
Old Aug 14, 2006 | 09:47 PM
square_1's Avatar
I would get the stuff for practically free. I am buying a D16z6 for really cheap and I am hoping to rebuild it some, put an Si tranny on it, and then put it in my DX swapping auto to manual in the process. It will be a lot of work but we will see how it goes. And then I was thinking of trying to build a turbo kit.
Thanks.
Old Aug 14, 2006 | 10:06 PM
doublethink's Avatar
cheap way, get an HF manifold.
the HF model crx has the cat converter where the header would be on a normal setup.
you can get a flange made (or buy one) to bolt up that 14b to the hf manifold.
the piping aside from what i just mentioned is obviosuly DIY.
check out homemadeturbo.com for more ideas about doing what your thinking. they have a forum too.
Old Aug 14, 2006 | 11:50 PM
B16aDasher's Avatar
Default Re: Eagle talon turbo? (doublethink)
i believe the 14b is only on the stick 1gens.
Old Aug 14, 2006 | 11:59 PM
bag's Avatar
bag
Default Re: Eagle talon turbo? (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher &raquo;</TD></TR><TR><TD CLASS="quote">i believe the 14b is only on the stick 1gens.</TD></TR></TABLE>
yes buddy..the auto's come with 13g..then the 95+ come with the T25 turbo..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by square_1 &raquo;</TD></TR><TR><TD CLASS="quote">Are turbos pretty interchangable? My friend has a 92 Eagle Talon, if he sold me his turbo and intercooler would that be usable in a 89 Civic Hatch?</TD></TR></TABLE>
yes sures..use a hf or 88-89 std manifold with adapter plate made for the dsm 14b flange
Old Aug 15, 2006 | 08:33 AM
JLefevers's Avatar
Default Re: Eagle talon turbo? (bag)
try to get the injectors off of the talon to
Old Aug 15, 2006 | 03:22 PM
mullenite's Avatar
Default Re: Eagle talon turbo? (91crxturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">13g = 3000gt/GTO/Stealth.....the 14b out of a talon/eclipse isnt bad...kinda small but good for a budget build</TD></TR></TABLE>
automatic 1g dsms came with 390cc injectors (same as stock stealth/3000gt) and the 13g turbo. the GTO came with 15g turbos and *i believe* blue top injectors, not positive on that though. manual 1gs came with 14b and blue top 450cc injectors and all the 2g cars (auto or manual) came with a garrett/mhi hybrid t25 (smaller than a 14b and bigger than a 13g) and black top 450cc injectors.
92hatchattack
May 5, 2009 02:25 AM
92hatchattack
hondaboyz94si
Dec 10, 2005 08:40 PM
ChaseIntegra
Aug 15, 2004 05:20 PM
